kydex...
  • kydex...
    Hey guys, found out about this thermoplastic called 'Kydex' which may help a few of you with custom mods
    basically you heat this in the oven then mold it around your 'negative'
    http://www.knifekits.com/store/s-pag...main.htm~smain
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    That's good stuff, I have several knife sheaths made from it.
    Failure is not an option....
    It's installed by default on every version of Windows.
      The problem is the behind the face fabrication.. Kydex will make a wonderful face, but it won't give you all the clips and stuff in back to put it in place. It does have it's place in other things though. That's a good site too, it's hard to find decent kydex distributors like that.
        that's why you make the clips, use the stock ones, fabricate new ones, etc. Thermoplastics allow you to heat solder them together. So, make a clip, heat up both sides of the joint and hold until it cools.
        Same with abs.
        What's the strength of this compared to abs of same thickness?
        2007 Chrysler PT Cruiser TE
        Car PC Progress:
        View my
        Worklog
        Road Runner Skins
        Website
        Favorite thread EVER!
          Same with abs.
          Pretty sure it's stronger. They use it for gun holsters for the military.
            Do you still have to thermoform the sheet? It seems your saying you can just fold it over and your done.
            Let me know
            thanks
            2005 Ford Mustang GT <- - - UPDATED PICTURES
            2003 KAWASAKI Z1000 - CUSTOM MODZ
            MBK (AIM = IllMBKllI)
              I think that says right there, thermoform plastics have to be heated to be formed...
              Car PC Progress:
              View my
              Worklog
              Road Runner Skins
              Website
                Same with abs.
                Never tried it, but kydex is kinda weird.. never worked with other plastics, so I can't compare. but I've got some scraps around, I'll give that a shot and let ya guys know in the future sometime.
