homemade homelink roof console
  • homemade homelink roof console
    Ok, here goes, I was jealous of my girlfriend's audi's built in homelink system, and was tired of having two different garage door openers bulking up my sunvisor. So I looked on ebay to find one for my car. There was hardly replacement visors, let alone any with homelink built in, and no overhead consoles for this car. So if you can't find it, make it.
    I started by buying a module that was pulled from a junked car with one in it.
    Then I tried to figure out where it would go, there's a great spot in between the visors on the headliner.
    Next, I took the unit and measured out a piece of thin plywood, and cut out the hole in the center of it.
    Then, I wrapped the unit in cloth and applied fiberglass resin, then a layer of fiberglass mat with more resin.
    Then, after it cured, I sanded it down, applied bondo filler, sanded again, more bondo, and so on until it was pretty smooth.
    Originally I planned on painting it, but while I was waiting for the bondo to cure I found some vinyl that matched my dash and picked up a yard for a couple bucks.
    After it was smooth, I wrapped the unit with the vinyl and used spray adhesive to get it to stick.
    I then cut the excess vinyl, and applied industrial strength velcro so that it will stick to the headliner.
    I wired it up and programmed the buttons. Now it actually looks like it came with the car.
    Pictures are worth a thousand words, so here's a few thousand of them:
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Me too, me too!
    Looks good!
    Here's how I did mine:
    Original Homelink from my ex Mitsubishi Eclipse '98 GSX:
    Click image for larger version
Name:	Eclipse Homelink.JPG
    Note: This photograph does not belong to me.
    Homelink Taken apart for soldering wires:
    Homelink assembled with RJ-11 wire sticking out:
    Buttons & LED assembled and housed on the monitor's bezel:
    Finished:
    [Homelink on the left, PC Reset & LEDs on the right]
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
      nice, anyone else do this? It's nice to show that it can be done, for fairly inexpensive. I got my module from a 96 dodge avenger on ebay for about $30 shipped, and already had the fiberglass resin and bondo, but these can be had for cheap too. Homelink sells the modules for around $200.
      BTW, ours are probably the same part, since mitsubishi and dodge shared parts at the time.
      Car PC Progress:
      View my
      Worklog
      Road Runner Skins
      Website
        oh, bump, I added the other two pics. I didn't happen to take any prior to the first one since I was so eager to get it done.
        Car PC Progress:
        View my
        Worklog
        Road Runner Skins
        Website
