'95 Accord lill bezel first try
  • '95 Accord lill bezel first try
    here is my first try at custom bezel with 7" lill i will post picture as i make progress, any tips, comments would be great
    Supplies:
    After Epoxy Glue:
    After Bondo Glass:
    Bonds Glass again after sanding:
    Looks okay. stay away from the inner edges of the screen, you dont want to have to correct those and have it mis shapped.
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
      well after two rounds of bondo glass and hours of sanding, it looks like this:
      is this good or should i apply more bonda glass if not bondo filler thanks
        Before you add any type of filler, that needs to be sanded down even and all the bondo glass needs to be removed from the button areas. Take a flat head and break out the filler in the holes. You want the bezel completey even with the body glass, and then to just use the regular body filler to get a smooth surface. Prime, then refill with your putty any pinholes, prime, re sand
        If you give up, send it to me, I can finsih it perfectly
        AIM: Exus28
