How to make easily internal bracket to support 2 din navi
  • How to make easily internal bracket to support 2 din navi
    Hi guys
    My car has the following openings in the console:
    From the top to the bottom
    1,5 Din size - ACC
    1 Din - ashtray
    1 Din - Radio
    1 Din - CD player
    I want to install and AVIC-D2 (2 Din) head unit at the highest level of the console.
    The problem is that the metal bracket (internally) expands only up to the second level (where the radio is).
    How you suggest to extend the metal bracket all the way to the top? Do PC shops have this kind DIN bracing brackets?
    I know it's kind of too personal how each fabricator will do it but I need the easier and neatest way...
    Of course I'll also need o cut the console in order to do it, but I've done that in the past so I have some prior experience (good thing is that I also have a second console panel waiting in case I fck it up )
    By the way here is a similar dash (latter model-when saab moved ash tray to the bottom of the console):
    Chris
