Need tips, Escort 8" in dash fabrication
  • Need tips, Escort 8" in dash fabrication
    so, i need some help with this.
    A moron friend of mine said that he could do this for me... And so i delivered the car to him in good will and hoped for a good result. But as you can see at the pictures.. This did not turn out well So now i`m asking for some tips on how i should do this?
    ive been thinking about getting a new dashboard.. or can i fabricate something myself?
    Also added a mini fabrication i did
    Bought an volt meter for sticking in your 12v output. Found my screwdriver and did the magic :P Drilled some holes in my dash and used sandpaper for last finish and fitting it properly. Glued and wired it up. All this took about an hour :P
    Sorry for typo`s...
    --Dizzey
    Wow man... That doesn't look good at all... Friends suck sometimes! I'd say use what you have, and try fabrication. If it turns out crappy, no harm done, no loss anyway since you are thinking about buying a new one anyway. All kinds of how-to's and projects around these parts... surely help you get on your way.
    Tidder
    Try RevFE
      That whole dash piece needs to be pulled from the car and the bezel needs to be molded in, and then the dash p[iece needs to be repainted,
      Brian @Nexations Creations
      Specialist in Custom Interior Fiberglass OEM Replication Work.
      AIM: Exus28
      E-Mail: [email protected]
        Hahahaha, wth kind of help was that, if any?
        With so much space available, you could also just make a mold around the screen in order to place it flush if you're not looking into molding it in place. You will have to repaint the entire dash piece.
        I would be really ****ed with your friend
          http://www.carputerforum.nl/carpc/showthread.php?t=2136
          This isnít my car, but its an escort, look at the pictures and you get an idea what you have to do, i can translate bits of it for you if you want, i am not gonna translate the whole topic.
          Cold weather mobo list: Copy the list and add your board
          my hidden screen in action (youtube) , the worklog , RR Volvoskin
            Are you sure you guys are friends?
            "A rose by any other name is still a flower"
              Thanks for answers
              I think i`l try to fix this one by my self :P with some fiberglass or something
              but does someone know how to make the "sand paint"? the plastic is blue with those little dots in it.. If you guys know what i mean?
              I tried to make my friend pay for this mess, but he wont.. so i guess were not friends any more :/
                Sue him for a new dash
                  wow, thats a crappy job,
                  If you lived close to me I would help ya...
                  or even do it for free, because I feel bad for you...
                  Personally I like to use bondo, because to me its easy to work with. I use cardboard to cut pieces if I'm fabbing something, then bondo over it to get the shape. That way you keep the bondo to a minimum. I can send you some pics of what I've done if you need some tips..
                  oxleyr at gmail dot com if you need help...
                    If only it was that easy :P i probably would have
                    Thanks for that i would love some pics of your work.
                    You got a pm with my email
                    Thanks for answers people
