1999 Honda Civic Bezel
  • 1999 Honda Civic Bezel
    I'm in the process of making this 99 Civic Si bezel. I'm making this bezel so it can be removed and it will fit perfect in the opening of the bezel.
    So far it's looking really good and the fitment is perfect.
    Below are some pics. I'll post more as I continue. I should be done this weekend with the entire system. Enjoy.
    1. I didn't take pics of the beginning steps. For the screen I used a Lilliput 629. I had to cut the bottom part of the screen in order to make it fit. I also had to add to both sides material in order for it to fit nice and snug. Below pics are after filling, sanding, primer, and repeating the process until it was ready.
    2. Final coat if primer. I got the urge to do this hours before, but I wanted it to be perfect
    3. This is the result after 3 coats of nice flat black paint that has a rubberish finish All I have to do now is install the screen and figure out where I'm going to place the 2 usb ports
    4. Ok, this is with the screen complete and installed. The amp and computer are both installed. I placed the power distribution block under the cup holder because it's hidden once the cup holder is installed.
    5. Close up of computer and amp. All connections to amp were soldered and shrink tubing was used
    6. Everything complete and installed except the seats. Done!
    Why would you wanna remove it?
      In case the car is sold or for any other reason. But my main reason was because I love how the OEMs look and this is what I'm trying to achieve. I have it primered and ready for paint
        looks good so far!
        Brian @Nexations Creations
        Specialist in Custom Interior Fiberglass OEM Replication Work.
        AIM: Exus28
        E-Mail: [email protected]
          Thanks man. Hey, do you know how I could restore the paint of the bezel? I cleaned it with alchohol and for some reason the paint was rubbing off while I cleaned it. If I can't find how to get the consistensy of before, I might have to repaint it. I think that I PMed u about it before
            Yea, I am not sure if I Pmed you back about it, I believe I did because I remember saying something like once the surface has become tarnished, that you can get never get it back to normal, because the paint is actually removed. Just sand it down with like 400 then 800 wetsand it should be good to go after that
            AIM: Exus28
              1st post updated.
                Done!!!!!!
                  That looks really good, awesome install!
                  2007 Chrysler PT Cruiser TE
                  Car PC Progress:
                  View my
                  Worklog
                  Road Runner Skins
                  Website
                  Favorite thread EVER!
                    Looks good man.
                    '02 GTI
                    [Routis '04] [Opus 90W] [160GB Maxtor HD]
                    [Lilliput 7" TS] [VIA M10000] [XMPCR]
                    [512MB RAM] [Custom housing]
                    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
                    Progress Meter: [==============|] 99.9%
                      great Install, clean work man!
                      AIM: Exus28
                        very nice set up, this is probably the cleanest i've seen because it looks almost stock.... so you didnt have to cut/mod anything on the bezel? i want to do this with my '00 civic
                        also would any 7" screen fit like that? or only the Lilliput 629?
                          I found this old thread and was wondering where i'd find paint that would match the stock Honda interior plastics. I've got a '04 Accord and want the interior to match as best as possible.
                          Awesome work BTW.
                            sem satin black, sem texture
                            i do the panels for the accord in the lower cubby all the time
                            AIM: Exus28
                              Thanks Nexson.
                              I have a single Honda (Pioneer) 6-disc cd changer kit... see below.
                              I've heard the double DIN head units will fit in the Honda part but there will be a small gap on either side of the opening.
                              Is there a quick fix rather than filling and painting the whole piece?
                              tx LBJGH
