Another blow to my build, help and opinions please!
  • Another blow to my build, help and opinions please!
    Originally posted by yaniv View Post
    I love the cactus
    How are you planning to keep the screens up? If the car shakes even a little the screen will flop right back down like this.
    I was going to put metal plates in the lid and have magnets hold it up and hold it down when its open and closed.
    I'd bet you could get a boneyard dash to work on and eventually give to Brian for fabbing. Is the dash surface steel, plastic or vinyl?
    By the way, this is looking so good that you ought to change the thread name to "Another direction for my build . . ."
    My Durango has a dash with unique texture. I cant seem to find it, so I went ahead and cut the dash. The screens now close 100% percent. the dash is vinyl.
    I love the cactus
    My parents have this weird thing about looking countryish............. I make fun of them all the time. Once again magnets will hold it up....
    PS why is the year 2001? wow Mp3Car forums has weird issues sometimes.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Well after moding some sunvisor flip downs to hold EBY701s, and working on this project for almost a year (the begginning of my build), I have decided to trash it. The EBY701 had such a thick wire or wires, that it required them to come out of the side of the visors then up into the headliner, this caused the sunvisor to be unable to move side to side to block the sun (very annoying). I also could not take the comments from people that swear vanity is the only thing that matters (the visors had no mirrors). So now I am ordering replacement stock visors......
    My new plan (were I need help) is to have the screens flip out of the top of the dash. The nice thing about the Durango is, it has alot of dash that can be used to hide things. So I wanted to have it so I can cut 2 square holes and make some kind of spring system so that when a user pushes down on the screen when closed, it clicks and makes a spring flip it up. Does anyone have any clue how this is done? Comments and ideas are welcome.
    Thanx in advance!
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
      try one of those sunglasses holder type things for a overhead console....im sure you can just use a spring on th eother end of the gear pivot....
      they usually have a 90 degree rotation or 1/4 pie slice with gear teeth on the circumference (apex)....
      they spring load it from one side to let is rotate down nice and "hydraulic like"...so my thinking is that you could spring load it backwards (anti rotationally) as an UP spring...
      to hold a monitor you'll need a stron one and a strong spring but that should work...
      my 06 altima has a nice up swinging door big enough for an 8" screen for sure but probably not heavy duty enough to swing up the weight of a monitor
      06 Altima..SER front bumper.
      CAR PC.....soon to be true!!
      Oshawa Canada!!
        Ill have to try that.... but in the end I think I am leaning towards a 'Flip the [email protected] thing open yourself " design, to make the screen very easy to build. I got my dremel off of ebay for $17.00 so Im happy. Has a nice speed setting and alot of attachments except the buzz saws, which I just ordered. Hopefully by the time the saws get here the plastic will be here. I am so excited to be starting this.
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1x Win 7 PC
          I really think that monitors do not belong in the visors. You should mount it lower somewhere on your dash. Easier+no movement.
          Get MediaEngine !!!
          Media Engine Download
            My bad.... here goes me not being specific. Thats actually what I am talking about, I ditched the visor idea because the cabling was a issue to hide and manage. The screens are being fabed to sit ontop of the dashboard, one iinfront of the driver and one for the passenger. I made models out of clay, but the new ones will be made out of abs plastic and use a combo of hinges, magnets and what not to work. Whats nice is that I will not have to cut much into the dash, just a tiny bit to get them to close properly.
            Here some pictures:
            Passenger Side:
            Driver Side:
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1x Win 7 PC
              Looks pretty good. Interesting that the Durango has a wicker dashboard support -- never saw one of those before. Must be only for here in the tropics, eh?
              I wonder if Brian (Nexson) could simply re-fab the whole top of the dash to fit the doors in and make it look completely OEM.
              If just enough is really good, then too much ought to be perfect.
              2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
                Make sure that when the screens pop open, they will clear the windshield. It would stink for them to open 85% of the way and be blocked by the glass.
                Also, try them out in the actual car to make sure they don't feel too far away. Mine flips up, but feels just a hair too far away.
                Want to:
                  thats what I am hoping.... Once i get the ABS plastic i will design one that he can intergrate into the dash. Only thing that sucks is that i will have to do light cutting into the dash to allow the screen to hold completely and flat.
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1x Win 7 PC
                    yes, that was the first thing i did........ Im trying to account for everything. I would feel stupid if i built them and the didnt have clearance.
                    4X MK808b
                    3x Perixx Touchpads
                    3x 7 inch Screens
                    1x Win 7 PC
                      Originally posted by HiJackZX1 View Post
                      . . . Only thing that sucks is that i will have to do light cutting into the dash to allow the screen to hold completely and flat.
                        I love the cactus
                        My Car PC project
                        Current status: Fabricating screen
                          Oooh...good point. For mine, it is servo powered, so it stays up as long as it has power.
                          Even over-centering the screen is no guarantee. A couple of times I drove around without power on the servo and had it slam shut once or twice. Them Xenarcs are pretty tough!
                          Want to:
                            Um what happened to my last post? The date says the year 2001 and its been bumped to the top ???????????????!!!!!!!!!!!!!!!!
                            Anyways: I cut into the dash and decided to go all out and rethink everything. Tell me what you guys think of my idea!
                            I cut the holes almost the same size as the screen, except one part that keeps the monitor from falling through. I am going to go into the main dash and cut off and seal to heater vents which are made to defrost the side windows, I live in FL so I dont need them and the one time I did use them, they dont really work to well. By cutting and sealing these vents, it allows me to cut into the really deep into the dash. So in the new holes I cut under the screens will go all the circuitry, which will have the monitor and components all in one little place. So now I am going to try to have the circuit hanging from a new floor panel that has vents in it to allow the head from the boards to rise up. I am also going to add a small switch so when the screens are closed there is no power to the screens, im doing this because I notice that when the eby701 is in standby, it still makes heat, and I do not want it to warp the screen if its closed all the time....
                            Someone in another thread helped me find a longer ribbon for the screen, but I cant seem to find a ribbon for the buttons, any ideas? I dont know what these ribbons are called, so its hard from me to find them.
                            4X MK808b
                            3x Perixx Touchpads
                            3x 7 inch Screens
                            1x Win 7 PC
                              I love the cactus
                              I love the cactus
                              PS: I posted this message yesterday, but MP3CAR was messed up and put the date as 12-11-2001, so it bumped it up to the top and didnt notify anyone a message was posted.
                              4X MK808b
                              3x Perixx Touchpads
                              3x 7 inch Screens
                              1x Win 7 PC
