Not a Monitor, but still Fabrication! Accord Dual Gauge Pod, (nexson) 56k Warning
  • Not a Monitor, but still Fabrication! Accord Dual Gauge Pod, (nexson) 56k Warning
    more pics to come tomorrow
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    Hey Guys!
    Coming to you with a Dual Gauge Setup on the Speedo Cluster.
    A little while ago I had done the single gauge setup, which can be seen here:
    http://v6performance.net/forums/showthread.php?t=90489
    This is pretty much the same setup, but with an added gauge.
    Here is the work thus far that I got done today. The next few days I will be doing a lot of sanding and shaping. I hope to be done around the weekend maybe.
    Enjoy!
    AIM: Exus28
      hey man, thats nice...
      Where are you located?
        cant wait to see more pics, also maybe a "parts list" of all the chemicals and products you are using as you use them, jsut an idea THANKS!
        MY build...a walk thru, finally getting to it
          more pics to come hopefully today!
          AIM: Exus28
            Hey Guys, coming to with an update from the past few days. Right now the project is at about 65% done and I have about 70% of the sanding behind me, (thank god).
            Anyhow from where I last left off I added 2 layers of 1.5oz mat which was more then strong enough. I also added a few more small layers to areas where they where low and need to be built up for shaping.
            In between all my glass coats I did the sanding of the fiberglass to get the cluster to be as perfectly shaped as fiberglass is going to be without filler. I went through about 3-4 sessions of glass and sanding, this was primarily the strength stage in the project.
            Next, (today) I moved onto the Duraglass, went through about 4-5 session of filling, shaping and sanding, sanding, and sanding and sanding and sanding, did I mentioned I had to sand lol. This is my least favorite stage but the most progressive one.
            From here, I move onto the top gauge which needed a little work to make it fit with no gaps, so I tapped off the gauge and added a little duraglass which gave me the look I was looking for.
            At this point I will spray some primer to show me my pits/pinholes etc, which I will then fill in with duraglass again, then anything small I will take care of with Xtreme and possibly spray with Slick Sand to fill in the vinyl texture once I have sanded it down.
            Enjoy.
            AIM: Exus28
              Update
              Well I am almost near the end.
              Since the last update, I have filled in some areas with Duraglass, then primed. I did about 3-4 sessions of primer-ing to see where I stand and where my defects are. Once I was done with the duraglass, I filled in a couple of areas that I wanted Xtreme to be filled in with because I just need a skim coat. Xtreme is the white-ish filler.
              After all that I sanded it down with 320 and then proceed to load the gun with Slick Sand which is an very high build primer, which I needed to fill in the original texture so a new fresh even texture can be sprayed over the whole project. I put the slicksand on heavy to fill in everything because most of it is coming off anyways.
              This is where I am at now, I am about 85% now.
              AIM: Exus28
                that looks soo good as always man i want to go out and buy some new tools, i cant wit to get into my next house have a shop set up jelouse!
                  hehe, thanks man!
                  AIM: Exus28
                    AIM: Exus28
                      good work as always almost looks ruberized, but i know its a factory textrue paint
                      great work man!
                        Thanks Man, That facotry paint is a pain in the butt to work with because it sprays out and dries really rough so it must be sanded down correctly to leave a smooth finihs but not sanded down to much to loose the texture.
                        Really diffucult.
                        AIM: Exus28
                          WOOOOOW dude thats awesome....Looks completely factory....
                          Good work man...
                            thank you!
                            AIM: Exus28
                              Looks awsome, would be better if both gauges were the same, but never the less, awsome
                              Some days your the bug, Others your the windshield
