*How* to mount display (2002 Frontier)
  • *How* to mount display (2002 Frontier)
    Hi all, new here. I have a 2002 Nissan Frontier, and I'm planning on getting a Xenarc 700TSV.
    Here's a picture of the dash (not mine):
    As you can see, there's a 2-din stock stereo, perfect for a display; and the recess underneath is where I'll cram the computer.
    The stereo opening is exactly 7" x 4". Xenarc lists the 700TSV dimensions (with bezel) at 7.75W x 4.75H x 1.38D.
    Any ideas on how I can mount it either with the bezel or without? I'm worried about the buttons on the bottom of the display not fitting. But the biggest question is how to mount the display. Epoxy? Screws? I'd like to have it as flush and stock-looking as possible, however I don't have a shop and I'm not a fabrication guru.
    Thanks!
    Welcome
    If I were you I'd check in the fab section. Lots of great people working in that part of the forums
    For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
      Check out my work in my threads. I'll get the job done, people will think its stock
      Brian @Nexations Creations
      Specialist in Custom Interior Fiberglass OEM Replication Work.
      AIM: Exus28
      E-Mail: [email protected]
        Check out the VIA ARTiGO PicoITX kit for the computer. I don't know how big that space is, but the ARTiGO may fit pretty nicely; its dimensions are 5.9"(L) x 4.3"(D) x 1.8"(H) (15cm x 11cm x 4.5cm).
        If just enough is really good, then too much ought to be perfect.
        2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
          Hey, this is unrelated but maybe you can help me out. I have an 02 frontier with stock stereo and I just bought a PAC-OEM harness with RCA outputs. Did you install something like this? (I see you have RCA outputs, but did you make that alteration?) And how did you set your stereo to "AUX"?
          Any help is greatly appreciated.
            Originally posted by jsd8cc View Post
            ...I'd like to have it as flush and stock-looking as possible, however I don't have a shop and I'm not a fabrication guru.
            Thanks!
            No Problem!!!
            STEP 1:
            Get Nexon's mailing address.
            STEP 2:
            Ship your dash parts to Nexon.
            Step 3:
            Get finished part from Nexon and install.
            Step 4:
            There's no step 4... Job's done and you didn't even break a sweat.
              +1 for nexon. He did my 2006 maxima. Came out great.
              CarPc
              Project "Driver"
              Planning [99.9%]
              Parts Collected [98.5%]
              Installation & Fabrication [98%]
              Total Completion Level [96.9 %]
              http://www.mp3car.com/vbulletin/work...ct-driver.html
