First time bezel Fabrication
  • First time bezel Fabrication
    Hi guys, here's some pictures of before and after my bezel work. I took example on the Turbocad thread, he is the real bezel KING!!!
    SO here it is....
    Car: Acura TL 04 6sp
    FrontEnd: RoadRunner
    Skin: DigitalFX 3.0
    Product used: Dynatron 660 EPOXY, Red primer, Flat Black Enamel Paint
    The screen: Xenarc 700TSV 2008
    OEM BEZEL
    Lets start!! Step 1
    Step 2 After a lot of fitting and Sanding + 3 primer coat
    Step 3 Test fitting
    Step 4 Painting
    Step 5 - FINAL INSTALL
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Looks OEM -- fine job. And you couldn't pick a better guy to emulate.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
      sweeeeeeeeeet how about some step by step so we can learn oh masterful one...
      CarPc
      Project "Driver"
      Planning [99.9%]
      Parts Collected [98.5%]
      Installation & Fabrication [98%]
      Total Completion Level [96.9 %]
      http://www.mp3car.com/vbulletin/work...ct-driver.html
        the king :
        http://www.mp3car.com/vbulletin/fabr...ory-bezel.html
        Final Install
        CarPC progress: 95%
          I know this is probably the wrong place to ask, but do you have any other info on the integration? Did you input to factory stereo (I see it's still there below the unit).
          Nick - 08 GG Element
          Custom 3D-CAD Design, Reverse Engineering and Fabrication
            Yes I kept the factory stereo and used a small aux device to get the audio from PC to Stereo...I'll find some time to explain tonight or tomorrow night....
            Final Install
            CarPC progress: 95%
              What paint is that?
              Play with it, 'til it's broke.
                I used Flat Black Enamel paint (engine paint). Been a year now and it didnt chipped or changed color ....just perfect!
                Final Install
                CarPC progress: 95%
                  I'm impressed! That paint turned out VERY OEM! (as did the entire project, but from the pic angles, the paint looks surprisingly perfect!)
                    The paint looks just like OEM and even better in my opinion, the only thing that bothers me is that I didn't quite finished my bezel the way I wanted....I'll have to get back on it when summer comes back!! Thanks for the comment man, I appreciate!!
                    Final Install
                    CarPC progress: 95%
                      Here's what I used to route my sound from my OEM Stereo to my carPc
                      1 : http://www.logjamelectronics.com/piex3hon03.html
                      2: http://www.amazon.com/PIE-X3-Triple-.../dp/B000PHHPSI
                      Simply pick the right model for you needs....and thats it!
                      Final Install
                      CarPC progress: 95%
                        How's the 700TSV at night? Not too bright I hope (i just ordered one...)
                          Very nice!
                          FAQ to the FAQ - Great Starting Point
                          My 2006 Honda Accord Carputer - Work In Progress
                          My 1997 Chrysler Concorde Carputer - Died
                            Ok, THREAD REVIVAL!! (its ok since its mine )
                            With all the background and knowledge I gained with this Mp3Car forum, I took everything a part and started my BEZEL again
                            This time I'm integrating a MacMini into the Glove Box and going for the Navi Display Bezel.
                            I'm still using the same product Dynatron 660 which is the best product I tried so far for plastic!!
                            So here is a teaser of my new bezel that will probably be finished and installed next week
                            Preparation and first Dyantron work
                            After shape is ready....PRIMER!
                            Test fit 1
                            Test fit 2
                            Now, I need to work on the details, there's couple holes here and there but nothing major...it will all disapear with the next sanding step
                            I'll simply shape a little bit again with grid 80 and move on to grid 220...when all will be good I'll wetsand with some 1000 and then I'll be ready for PRIMER + PAINTING
                            Final Install
                            CarPC progress: 95%
                              Its all a process from here!
                              Take a block to that right side edge with some 220, it looks a little off
                              Brian @Nexations Creations
                              Specialist in Custom Interior Fiberglass OEM Replication Work.
                              AIM: Exus28
                              E-Mail: [email protected]
