Advice on how/where to put touchscreen
  • Advice on how/where to put touchscreen
    OK. I am finally going to bite the bullet and get a car pc, I am not sure on whether to go for a 7, 8 or 10" screen though. Looking at the pic below What do you gurus recommend?
    Its going in a 80 Series Landcruiser as pictured below. Do you guys have the screens mounted flat or are they tilted slightly towards the driver enabling a better viewing angle?
    I was going to mount it similar to this pic below so I can swivel towards me or the mrs depending on what its doing UNTIL I stumbled across some pics of the installs you guys are managing to do. !!
    I am looking at the cheap ebay 8 or 10" LCD's at the moment but am open to suggestions.
    You could easily fit a 7'' in your dash and relocate your aftermarket JVC. Looks like it'll be hard to reach so you better plan and check everything before going for it....
    Good luck!!
    Vmt
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
      Yeah I wanted to go bigger than a 7" and as for the JVC deck that will be removed as long as I can get radio to work through the car pc.
        You could go for a 8'' or 10'' but that means more $$$ and more fabrication with epoxy or what ever product your intend to use. It seems like a nice project....don't to plan everything before, it will give a bigger picture of my work needs to be done.
        IMO, you could relocate the JVC and get the audio from there (AUXILIARY).
        GOod luck with ur setup man.
        Final Install
        CarPC progress: 95%
          Wow that's a whole lot of devices!
          I would move the JVC as some suggested. A double din is a perfect place for a monitor.
          My Car PC project
          Current status: Fabricating screen
            Where did you get the monitor mount? I have been searching the forums for that type of mount for my 7" archos... touch screen, trying to figure a way to mount it in my BMW style dash.
              Its a custom job, I will post of some more pics of different angles tonight..
