Did I get the right kind of bondo?
  • Did I get the right kind of bondo?
    Hi,
    I'm planning to start my screen fabrication and would like to get your opinion if I got the right material. I'm no expert with working with bondo but hopefully with the aid of the stuff I read and seen in the forum I'll be able to produce something good looking.
    Thanks!
    My Car PC project
    Current status: Fabricating screen
    well yea, it is the right stuff, but it isnt the greatest
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
      I don't have too many choices. This industry is very lacking here.
      There was just one other material at the store. I can't remember the brand name (I can call them tomorrow and check) but the guy there told me it might break and that bondo is stronger.
      Do you have any suggestions and warnings of how to use this particular material well? I obviously want this to look OEM and smooth.
      My Car PC project
        IM me at exus28 on AIM
        much eassier to describe, the industry is not lacking there os tons of premium body fillers out there but jus not at your local hardware store.
        AIM: Exus28
          Thanks I added you to my contacts
          My Car PC project
            Damn, that's what I'm using.
              It just requires more work to do it correctly, I suppose it is alright for one timers, but I do this as a pernmament side job so I have all the best materials
              AIM: Exus28
                One of the easiest secrets to getting a good result is starting with good materials. Use what the guys with the sweetest results use. When Brian (Nexson) says "Use Rage products", that's a good direction for us to go. If we use lesser products, we get lesser results, or we spend more time making up for them.
                If just enough is really good, then too much ought to be perfect.
                2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
                  bond makes a premium product and when mixed it is blue not pink and it sands like butter!! it is light weight filler i think it is called bond ultimate or ultra
                  body shops use this type for feathering as it blends well. i used this in my 2007 tundra to get a gloss black finish. if you dont know, black shows all flaws and is very hard to pull off !
                    I would not use the normal bondo. I have finally made the perfect shape with it and I cant get these tiny holes out of the surface. I have tried filling them in and resanding and it just doesnt work. I have heard that Bondo Gold does work a lot better though and am looking into purchasing some myself.
                      Mibix, go to walamrt and pick up "spot putty" it is in a red tube, it is the only product from bondo brand that is actually decent, give it like an hour to dry though.
                      AIM: Exus28
                        I did my monitor today. I'm very pleased with the results. This material is not as bad as you make it sound. It does require a lot of sanding but the results are very good.
                        My Car PC project
                          After about a week of working on/off, I'm finally done
                          (bottom of page)
                          http://www.mp3car.com/vbulletin/show...ml#post1243770
                          More detailed photos on:
                          http://yanivp.livejournal.com
                          My Car PC project
