Newbie: Whats this part called...
  • Newbie: Whats this part called...
    Hi, first time caller long time listener, so be gentle.
    I'm going to fabricate myself a spring loaded popup dashboard monitor (don't want to go into all the hastle of motorised screens - http://www.mp3car.com/vbulletin/show...up-screen.html) - I don't see popping the thing up as a problem - but I need help keeping it down.
    I figured I'd need to use some of those (magnetic?) push-pop thingies, the ones where you push them down to keep it in place, then push it again to release it? But I cant think what they are called? Any ideas? Or any better suggestions?
    spring loaded latch? pop latch? something like that, haha...
    DON'T PANIC.
    Previous install pics in 2k3 S10
    Project CarPc V2
      Its a touch latch! Unfortunatly they seem to be a little too big for what I want.
        Sorry to get in on this after you'd already found your answer.
        There seem to be some pretty small ones out there. Maybe one like this will fit . . .
        If just enough is really good, then too much ought to be perfect.
        2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
          I have seen some sort of small ones at HomeDepot in the cabinet/hardware aisles. I used them for a project in highschool and they worked well.
          1.9in x 2.9in -- 47mm x 73mm
