EVO X Monitor Fabrication *WORKLOG* Nexations Creations
  • EVO X Monitor Fabrication *WORKLOG* Nexations Creations
    EVO X Carputer Mold, Button Panel custom Fabbed in.
    I will let the pictures do the talking
    Brian @Nexations Creations
    Specialist in Custom Interior Fiberglass OEM Replication Work.
    AIM: Exus28
    E-Mail: [email protected]
    wow. beautiful work as usual. love the button placement. ergonomic.
    2007 Mini Cooper eee PC worklog
      Goes without saying, Great work Nexson.
      If you cant DODGE em, RAM em.
        As always, your work is amazing, even at the fine-detail level.
        One thing that might add to the impact is comparison shots: at the end of the series, put the "before" picture, and accompany it with an "after" shot of the finished piece in the same position as it is in the "before" picture. I think the "Wow!" factor might be even greater.
        You might even go back and add that "after" shot to the first post, too.
        Fine work, Brian.
        If just enough is really good, then too much ought to be perfect.
        2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
          Makes me sick! ('cause i wish i had the talent)
          OLD SYSTEM (DEAD)
          Intel D945GCLF2 Dual Core ATOM
          Lilliput 7" 629GL 2008 LED Backlight
          BU-353 USB GPS Receiver / iGuidance / IGO8
          M2-ATX Power Supply
          RideRunner Front End / Various Skins
          Windows XP SP3
            I just got it and installed the screen and buttons.
            Works great and the quality is amazing.
            Here are some pics, sorry for the crappy photo but its from my phone.
              Thank you! The button was one of the first that I have done like that. It sometimes amazes me how I can picture it all in my mind before I even start. I am glad to have already worked on an EVO X
              Thanks! Always Appreciated!
              Fine work, Brian.
              Hey! You see I took your advice for a little background in the final pictures. I will admit that it can get alot better. That is actually just the fleece I use to wrap each job in before I send it out. I have to check out the fabric section to find a nice material to use. Also, I will have to take your advice on the before and after pictures. Usually I am too excited to get it shipped out ASAP for the customer that I miss the chance to do the final, final pictures.
              We each have our talenets. You possess talents I do not have, and it goes on for everyone else. I have just chosen to capitalize on this talent, and through MP3car.com, I have found what I truly love to work on.
              Thanks! I always have to hold my breath when I send fabrications out, just because who I am, I am not satisfied until the customer is satisfied with what they have paid for.
              Looks great and I can't wait for the install. Link me to the thread, if you post on the EVO forums.
              AIM: Exus28
                Will do.
                  thanks!!
                  AIM: Exus28
                    I wish I had your body-filler skills!
                      Very tidy build. I especially like how you angled the buttons. That's a very OEM touch.
                      Nick - 08 GG Element
                      Custom 3D-CAD Design, Reverse Engineering and Fabrication
                        Is that a special paint, or did you just do the 'misting' application?
                          I usually put several light coats of sand-n-fill primer like that. If you use that (it's basically very thick primer) you can get the part looking really good and don't need to be an expert body/filler man.
                            So your finished product is only primer? Looks realy good....
                              I'm not sure what paint he used, but when I do it I usually get the automotive grade exterior paint. When I do interior stuff I usually spray a few coats of the exterior paint, but from a little further away than recommended. This gives a good color, but slightly textured finish that even further hides any imperfections.
