1999 Jeep Grand Cherokee 2 DIN Bezel and Case fabrication.
  • 1999 Jeep Grand Cherokee 2 DIN Bezel and Case fabrication.
    Hi to everyone. Starting from this post I will report to you my fabrication work fro my 1999 Jeep Grand Cherokee. I bought a ByByte bezel and a 7" LED Backlight VGA screen from Vitrolight (China). The panel is the same used on new 629 lilliput. Started to work on bezel, already done for my previous all in one double din, I had to enlarge a little bit the hole, due to the bybyte frame is a little bit higher and larger than my previous 2 Din. For the case I am using an old 2 din radio case. This is first step:
    It's a Jeep wouldn't understand !--------------------------------------------
    This is the monitor:
      Carputer installed:
      Motherboard: Industrial PC
      Lanner inc. Model IAC-H672
      Form Factor
      Half-size, ISA
      VIA Mark processor, 800MHz
      VIA Mark + VT82C686B
      Award 256K BIOS
      Processor Built-in Cache memory
      System Memory
      512MB Max Capacity
      Socket SO-DIMM x1
      Storage Interface
      IDE x1
      SSD (CF Socket)
      CompactFlash I/II x1
      DOC socket x1, supports Msystem DiskonChip 2000 Flash memory
      10/100 Mbps
      RJ45 x1
      Realtek RTL8100B, Supports PXE
      VIA Mark integrated S3 ProSavage 4, AGP 4X Graphics support 36 bit TFT & 2 channels (2x18-bit) LVDS LCD
      8/ 16/ 32MB
      VGA DB15
      VIA V1612A with AC97 2.0 audio codec
      I/O 5x2 2.0mm Pin Header for Mic in, Line-in, Speaker-out
      I/O Interface
      FDD Box Header 2.54mm x 1
      RS-232 x1, RS-232/422/485 x1
      LPT Pin Header 2.0mm x 1
      4 USB(v 2.0)
      8-bit Digital I/O with pin-header (4 in/4 out)
      115k bps, IrDA 1.0 compliant with pin-header connector
      Mini-DIN PS/2
      Mini-DIN PS/2
      Bus interface
      PCI /ISA
      Hardware Monitoring
      VIA VT82C686B Super I/O including H/W Monitoring function
      VIA VT82C686B Super I/O with Li-battery
      Watchdog timer with 256-level time-out intervals
      Heatsink / Fan
      PC/104 x1
      PC/104+ x1
      Environmental Parameters
      0~60C ambient operating temp.
      neg 20~70C ambient storage temp.
      5~95% ambient operating humidity
      Physical Dimensions
      185 x 122 mm (7.28 x 4.8)
      +5V, +12V
      AT/ATX supports, 4pin +5V power Connector
      Operating System: Windows XP Home Edition SP2.
      HD: SAMSUNG HM160HC (149 GB, IDE)
      Radio: Silabs USB with RDS .
      TV: Stick USB DVB-T
      Navigation SW: Sygic 7.71 RC11 with Europe 2009 maps
      GPS: Globalsat BU-353 SiRFStarIII USB
      PSU/Controller: M1-ATX
      Steering Wheel: CarPC JoyCon
