Need ideas on how to accomplish getting a screen fabbed into my bezel please..
  • Need ideas on how to accomplish getting a screen fabbed into my bezel please..
    We just got a 2007 Dodge Nitro.. I would love to get a carputer installed but I just can't see how I would get a screen fabbed into the bezel..
    Here is a blank bezel:
    And here is a factory image:
    The issue I have is the vents above.. I obviously don't want to lose them so I don't see how I could get a screen to fit..
    Anyone have any ideas?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    if its a double din , the 7" lilliput should fit right in ...
    just make brackets for it on the back of the dash piece
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
      You sure? It doesn't look like one would fit in..
      Maybe it's not a double din.. Maybe it's a 1.5 Din..
        tbird... never sure ... lol
        always trying though (;
        it could very much be a 1.5 in which case the spacing for the monitor shoould be extended a little on the bottom part of the opening... prbably another half an inch...
        my suggestion is ... get the widescreen 7" lilliput and then measure how much is needed to be extended to fit the screen itself (without it's casing.
          If I were you, I'd put the screen on top of the vents. Don't have to look down this way. and you have some kind of a platform up there already. Should not be very dificult. also I'd angle it a bit towrds the driver.
            On top of the vents? Not sure what you mean?
            Anyone photochop?
              Anyone photochop?
              I don't have a pshop at work, but what I mean is - there is a plastic platform on top of them. Look at how navigation screan is located on Volvos. May be you'll understand better what I mean.
              your monitor would be continuation of bezel this way, protruding up your dashboard
                OMG, the answer is right in front of you!!!!!!!! By the way I love the Nitro, that SUV is so f^&kin hot, to bad its to small for my family.
                See at the bottom under the radio area there is a part that that slants out? Simply make that lower and that should give you the room you need. You dont have to worry about moving the vents then. I would go with a EBY701 because they are thinner at the bottom and have the buttons on the side. If you are taking the screen out of it original bezel then it will fit as is, you may have to do mild cutting. On mine, I had a slant at the top so I had Nexson move the slant up to allow the screen to fit. In your case, your moving the slant at the bottom down.
                1X Ainol Novo Flame Tab
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1X 7 inch motorized Screen
                1x Win 7 PC
                  HiJack, you got before pics of yours? So you're saying if I took the screen out of the bezel it would fit into that opening without modification? I just wouldn't have button access??
                    Hmmm.. Wonder if something like this would work? Looks like maybe NO fab needed?
                    http://cgi.ebay.com/DOUBLE-DIN-LILLI...d=p3286.c0.m14
                      Just to give you an idea. Just make it pretty
                        yes, my bad.... As you can see I had the cr@ppy 1.5 opening.
                        4X MK808b
                        3x Perixx Touchpads
                        3x 7 inch Screens
                        1x Win 7 PC
                          It looks long enough, that it may fit the screen complete. The best thing to do is buy the screen and try it. You will have to end up buying one any ways for your install. Just make it the first thing you buy. I do not like taking the screen out of the casing. I felt that the EBY701 looks like something Dodge would put in its car. I wanted the HU look, not the intergrated looks. Even my dash top screens still use the EBY701 bezel even though the buttons are removed.
                          That screen you linked to is basically the EBY701 but with a custom bezel. It may work. Email the guy for the measurements of the bezel, then measure yours and compare.
                          4X MK808b
                          3x Perixx Touchpads
                          3x 7 inch Screens
                          1x Win 7 PC
                            What do you think about that link I posted to the double din?
                              another idea i have - motorized screan from Mazda 6. I think it might fit in that location too.
