factory finish iphone mount fabbed into dash - 97 4runner
  • factory finish iphone mount fabbed into dash - 97 4runner
    Well, this is my first attempt at using epoxy, epoxy putt and glazing putty EVER, so I guess the title is misleading as I was attempting at a factory finish
    I'm very happy with the fit as well as functionality and the looks at night .. but unfortunately I'm still learning to work with the glazing putty and will definitely sand it down and have another go at it in the near future for a better final painted finish!
    any tips on getting a better finish is greatly appreciated!
    BTW, thank you Nexson (Brian) for your awesome work, pointers and inspiration, you are the FAB man!!! hopefully I will be as half as good as you when I grow up
    Stock 97 4runner dash
    My Stock Dash, when I first picked up my dirty 97 4runner with 500,000 KM on her!
    - Cut out left vent and cup holder (really dumb pull out dahs cup holder that had coffee spilling all over the place, and I installed 99 4runner center console cup holder )
    - epoxied in plastic filler and iphone dock
    - epoxied in plastic filler (piece of cup holder I cut out) above dock where vent was
    - used epoxy putty to fill in gaps as well a large build up above dock
    - taped iphone and jammed it in dock against putt and let dry to form iPhone shaped mold
    - pried out iPhone and peeled off tape
    - Sanded epoxy putty with 220 grit sand paper (dry)
    - first coat of bondo glazing putty (sanded with 400 grit sand paper dry)
    - did this 3 times
    - also filled a few larger holes and straightened out the line under the dock with some more expoxy putty
    - Primed with filler primer ( 3 coats and then some more bondo epoxy putty and 400 grit sanding before 4th coat)
    - close up after 3rd coat of filler primer
    - 4 coats of trim black spray paint
    - poor quality iphone pick that I'll retake tomorrow and post!
    - car charger in back will run directly to uninterrupted battery power
    - audio in from Pioneer deck ran in back to the dock
    That looks like its removable.
      awesome job for just starting with epoxy
      - Project: Unified Car Control
      - Original OpenMobile Interface Designer
        The iPhone is definitely removable if that's what you mean! I basically just mounted and extended an iPhone doc.
          Looks lopsided. Is it straight up and down?
          Ampie Case
          256 MB DDR2 PC5400
          Xenarc 700TSV - VGA Monitor
          Intel D945GCLF Motherboard
          M2-ATX-HV
          2005 Honda Civic
            Congratulations! excellent job!
            My Site: www.fuegomp3.com.ar
            Renault Fuego 84 Carpc & full worklog
              yes it's a little crooked to the left , that I will probably leave as it doesn't bother me too much, but the finish bothers me so I will definitely be sanding and filling and repaint soon!
              man I didn't think the lopsidedness was that noticeable
                members of this forum are some of the most picky people in the world, one centimeter to the left will be noticable
                  We prefer to be called perfectionists....
                    Its because you can see a gap on the right side...so it looks like its leaning a lot to the left...no need to go crazy, just bulk up the right side a little bit and it should look great.
                    openMobile - An open source C# Front End (why choose openMobile?)
                    - Always Recruiting Developers -
                    Like what you see? Donations are always welcome
                      I like the idea, the only thing that deters me is knowing I will replace my phone almost every year. Far sooner than I plan to get rid of my ride. And knowing Apple, their next gen design will not fit. I think if i were to tackle this I would make the dock part a removable component that can be changed for my next device.
                        +1
                        Great job for the first try however! I would recommend blocking or redirecting the left vent to the right - you don't want hot air blowing on your iphone.
                          Originally posted by kraimer21 View Post
                          +1
                          Thx for the compliments
                          I actually did duct tape the left side and redirect all air to the right vent so there's no air hitting the back of the dock!
                            Cool, thx for the input.
                            Do you mean a gap on the bottom right corner of iPhone or all on the right side?
                              Summer!!!
                              I bet you're going to be sorry when summer gets here!!!
                              but otherwise it looks pretty good...
                              :cheers:
                              "Most of the users you'll see in this site are still learning specially me"
