My recent work log
  • My recent work log
    Here's some stuff I've been working on as of late.
    My neighbor had this awful crummy plastic bezel the he was using for some gauges. I made a new surface to house the gauges:
    I drilled holes through the mdf and plastic. Used quick set epoxy in a couple of ares just to hold it in place then CA glue for the rest.
    First layer of evercoat.
    A little sanding later.
    More gauges: right above the center console in the no longer used vent
    Had to cut out the center division between vents and secure a new surface for the gauges
    After some evercoat glaze and sanding the edges to get a nice bezel/curved corners
    Here's a shot of an extra identical vent an the new "gauge plate"
    Here's a shot of the two together
      Here's my cluster screen bezel. There were a bunch of versions and finishes. Initially I planned on this being an insert bezel so that I could go back to stock if I ever want to...
      I had masked the area and used epoxy putty to build the area around the hacked lilliput bezel [sanded with 40 grit first]
      Almost done
      Finish 1
      Way too flashy for me...
      Sanded it down and started trying a dupont flat black... I'm liking this better
      I finished this but decided to just go for a one-piece and go for more OEM look
      These edges were perfectly match previously but being that i want to join these pieces, I sanded it down to make a bit of a gap that I will fill...
      CA glue to bond the back
      Almost there
      I wound up using SEM trim paint. I covered the entire piece and baked it. Then I did a medium coat, allowed to tack, then followed with three dry shot coats from a far distance. This gives the paint a really nice texture. I'll have to get a closer shot for you guys to really see what I'm talking about.
        Here's a piece under my cluster. A simple graft project... again I'm using epoxy putty, CA glue, and Evercoat glaze as a finish.
        I have to clean up some goo from the tape on the edges but i'll do that later...
          coming along nicely, what did you do with the power button for the screen?
          Crown Vic Project Blog forum
          http://crownvicworld.servebbs.com
          http://www.cardomain.com/ride/3859896/1
          http://www.cardomain.com/ride/3851651
          http://www.cardomain.com/ride/2946960/1 (with car PC)
            I'm using the cigarette adapter for power. It turns on as soon as it gets signal from the computer. I'm installing everything on saturday. I hate taking the car apart for wiring...
              Your work looks very good! Sweet! I'll be keeping track of this one :-)
                Now that I have everything installed I see what you mean. I thought the monitor would come on if given power and signal from the VGA... I was mistaken. I've tried that "factory menu code" 588998 to no avail. I tried it so many different ways... I'm done with it. I cut off the button portion of the lilliput and glue it to the back. I will relocate the buttons to where i put the usb's/audio. I may be deluding myself, but I actually like having the option of turning the monitor on/off with the button if I so choose.
                Thanks dude.
                  More work:
                  Fabricating a place for the Lilliput controller board and a center channel.
                    Updates:
                    Update:
                    Now to wet sand paint,
                      nice work, where in ny are you located. im in nassau
                      01 Burb
                      http://www.mp3car.com/vbulletin/work...-suburban.html
                        Nassau County, Albany NY or Nassau, Long Beach? I'm in Throgs Neck.
                          long island, great work ya do.
                          01 Burb
                            Here's an update:
                            I'm doing another Civic 7" mold in... This time I'm going for a nice hard edge bezel
                            Maybe I'll get some paint on this soon...
                              Update to the new bezel:
