Painting Plastic - Best Practices
  • Painting Plastic - Best Practices
    I want to change the interior color of my German truck from mid blue to grey.
    What are the best methods and products for doing this? Obviously cleaning the removed sections is important. What should I do to ensure a long lasting professional looking job? Thanks.
    i would like to do the same. im scared of the paint layer cracking due to expansion/contraction from heat changes because the material is kind of soft almost rubbery
      I did a civic a while back. It had a hard plastic interior. Clean everything with a degreaser, then sand everything with 200 or 300 sandpaper. Then paint. I used a matt dupont black. Everyone thought it was stock. Its held up fine for as long as i've had it, since 98. Got rid of it in 94 or 95.
        Hahaha!
        But easy enough, clean it well (soap, degreasser, whatever) and then sand it with a decently high grit. Use good paint, that's all I can say. Paint intended for lightly sanded plastic. Krylon has a good line, "Fusion" I believe, which holds to plastic specifically.
        2001 Mustang Convertible Worklog
        Indigo Custom Frontend (Flash/Delphi)
        Blog
        Qube v1.3 Now Available at the mp3Car Store!!!!!!
        The simplest IO controller you'll ever use!
          Also spray extremely light coats and bake dry. If your cover the sub materials color on the second coat you're laying it on too thick. When I did it, i let it bake dry between coats and didn't get full coverage till the 4th coat.
          If you put it on thick it will especially without sanding first, you'll be able to scrape an edge up and peal it off in one piece like unupholstering a chair.
            Originally posted by colin View Post
            Hahaha!
            Sorry for the dyslexia... 94 or 95 that I got rid of in 2004.
              You need to make sure that you clean the dash with alcohol, also use an adhesion promoter and primer
              I painted my whole interior 4 years ago and it hasnt chipped or faded, i used dupli-color vinyl and fabric coating at autozone, its good on dashes doors seats and carpet
              Also sanding the plastic bad idea, it will make the finished product look like ***, most plastic dash components are textured, unless you plan on spending all day making it smooth removing all the scuff marks from the sand paper, resorting to filler primer in the end, dont do it, lol
              MY INSTAllS:
              http://www.mp3car.com/vbulletin/show...e-install.html
              http://www.mp3car.com/vbulletin/show...tallation.html
                Sanding wont ruin the surface,.. if you use the right grade, 200 or 300. Of corse using a 40grit will leave the surface chewed up. But just like you sand paint bewteen coats, so do you sand to prep for paint. You're not look to shape the piece as it is already the a finished piece, but sand (fine grit) will give you better adhesion.
                  What do you mean by "bake dry"? Putting plastic in the oven is also a bad idea, lol
                  MY INSTAllS:
                    Heat lamp dude. Getting the solvents out of the paint to speed curing and minimize the effect of shrinkage leading to cracks with multiple coats...
                      just giving you a hard time bro. lol
                      MY INSTAllS:
