Fiberglassing Tips?
This is a sticky topic.
  • Fiberglassing Tips?
    So I've never fiberglassed before, and I just tried using a Bondo brand Fiberglass Repair Kit, and it turned into a biiiiig mess really, really quickly. Does anyone have any tips? Is the woven fiberglass matt easier to deal with? The fact that I tried to fiberglass a really oddly shapped cubby probably didnt help things, as hell didnt break loose until I tried to start working all the different angles and nooks and crannies in.
    Edit: This cubby
    -Nick
    _____________________________
    www.mp3vw.com
    Ohh... I've fiberglassed a ton of crap in the last 6 months. It's difficult to get used to. ..Okay, in my experience fiberglass cloth is easier to mess with than fiberglass mat.
    As far as the cubby, this is what I'd do. Make a frame out of thin plywood or MDF. Then staple and stretch fleece (Sweatshirt material) over it and bruch on your resin/hardener. When it dries you can add layers of the fiberglass cloth to it to build it up.
    I'm making a little console for my AC controls that I had to relocate and it has a few curves in it (to match the dash, and this is the method I've used and it turned out VERY nice.
      One point to add to `ddt` regarding the "fleece (Sweatshirt material)", try to find material with as much polyester as possible. It sets up better and there is some material that the resin will dissolve, try a test piece of your material with your resin first to make sure it's OK.
      Chkdsk
      Shuttle ST62K, 80Gb, MediaEngine, Irman, Wireless NIC, Win2K, Blah Blah Blah...
        Did you steal my friends brain? Heh, he said the same thing. Only problem is I'm trying to do a shell inside the cubby. I'll have to go get some fiberglass cloth thins week, and some more hardener. Also, any tips on getting the fiberglass loose other than just prying?
        -Nick
        www.mp3vw.com
          Depending on what it is bonded to, you can try using some acetone or heat to remove it. But if it is attached to something soft, like plastic then be very careful. Prying may be your only solution; hopefully the resin is still a bit soft.
          If you're grabbing some cloth, maybe get some thinner (lighter) stuff and do multiple layers, it is much easier to form around corners. We used to put some different color paint in the resin so you could easily see the multiple layers as you are applying them, saves "guessing" where you left off...
          Chkdsk
            To anyone interested, here are some more fiberglassing resources...
            The12Volt.com has a Fiberglass section (as well as other things)...
            Alpine-Usa.com 2003 Honda Civic SI, Click on the Installation Photo's - it will take you a few hours to go through BUT it is extremely informative!
            The Glassman Forum at YahooGroups - not a pile of posts but very informative. Kinda of commercial orientate but still a lot of good info. At YahooGroups, search for Glassmancustomforum and you'll find it.
            I don't know how far MP3Car.com wants to get into glassing as it is a growing part of our hobby IE; do you prefer we send people to other sites OR do you prefer we help them out here?
            Chkdsk
              Bingo! But if the area was cleaned and prepped (meaning the resin will stick well) then good luck!
                Yeah, ive done a bit of reading on the glassmans yahoo group, and im trying to get the haphazard shell out of the cubby now. I laid down a few layers of masking tape over the plastic cubby, so Ill just get to prying.
                -Nick
                www.mp3vw.com
                  The best tutorial(s) out there!
                  http://www.carsound.com/cgi-bin/ubbc...=4;t=003210;p=
                  and
                  http://www.termpro.com/cgi-bin/ubb/u...;f=32;t=000549
                  Other fiberglass stuff.
                  http://www.eatel.net/~amptech/elecdisc/fibrglas.htm
                  http://www.carsound.com/cgi-bin/ubbcgi/ultimatebb.cgi
                  http://www.ofsoundmind.com/osm/install/glass.html
                  I have more but not on this computer. I'll post more this evening.
                  BTW the Glassman forums are good!
                    Start "prying" as soon as possible as the masking tape will start reacting with your mold and with the resin making it a permanent structure of your vehicle.
                    I use a good quality masking tape (7 day release) and usually apply Turtle Wax on top of the tape to assist in a mold release. You can also go one step further of using Tin Foil depending on how flat the surface is.
                    Chkdsk
                      i was gonna say but ddt beat me to it that www.termpro.com has a good fabrication/fiberglass forum. its dealing with the same stuff we are dealing with so it should be inspirational. i havent checked the yahoogroups i will look into that.
                        fiberglassing ... step by step
                        http://web.njit.edu/~cas1383/glassing2/
                        ~mike
                        Single Member of the "1000 Post and No MP3 Car" Club
                        PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
                        2000 Cavalier Z24 [###-------] Only 30% Done ... Still
                          Nice find. I bought a replacement center console on ebay months ago, and it should be finally showing up soon, so I'll have to do it in a more proper manner this time. I really knew about all of those steps last time, but I was an impatient bastard and now have paid the price for it .
                          -Nick
                          www.mp3vw.com
                            hiya guys
                            im in the process of building a complete fiberglass console for my car to fit my lcd and stuff
                            ive been taking photos during the process and if anyone is interested i can do a lil description about each one and post em up
                            donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
                              I'm a member at the www.fiberglast.com forums...and there are a few people that really know their stuff. Theres also an archive of very good threads.
                              -F
                              No Carputer YET.
                              A car I'm designing...
