Use ABS Sheets Instead of Fabbing?
  • Use ABS Sheets Instead of Fabbing?
    I have no fabrication skills, and unfortunately I have a large piece that needs fabbing. I have no CAD skills either, so I've drawn up what I need to do (the yellow parts will need to be fabricated).
    The curved white piece is the bezel that will hold an iPad and be visible. I've cut out the stuff that used to be in the middle (aircon vents, hole for hazard switch, hole for clock, and hole for defogger) and will be putting all that behind the iPad. To hold the iPad in place, I'm planning something similar to the semi-circular tabs that jr4284 made but with holes cut out so the air from the vents behind the iPad can get out. Since mainly what I need fabbed are large flat pieces, I thought I might be able to use pieces of .125" ABS and simply cover up the edges with bumper repair. How feasible is this?
    EDIT: To make it a bit clearer what exactly you're looking at there, I'm attaching a stock image of the original dashboard.
    The iPad will mount vertically in the dock, and stick up out of the top of the dashboard about 2". This should make it easily removable and allow better GPS reception.
    your drawing skills are a little ... hehe, anyways i think you might be better off using plywood and covering it over with fiberglass/mactac/fabric/paint or whatever might be easier for you since everything is flat. likely a little stronger too just my 2 cents SNO
      ABS will work, but how will you make the curved top piece with the half circles?
      Want to:
        I have the basic frame, but yes, I would have to fab the semicircles. Beats fabbing the whole thing IMO. I'm guessing I could just apply a chunk of bumper repair to either side and mold it from there?
          Might have to make a negative mold out of wood, then lay fiberglass in it and cut out the shape you want after it dries. See the pics in the DeLorean thread for how he did it for his bezel.
          Want to:
            If you have a good mold for the curved pieces, you can use a heat gun to soften the ABSto mold it into whatever shape you want, personally I think ABS would be a better platform for a beginner to start with, fiberglass requires a lot of prep work and can be really hazardous to your health if you breathe in dust or get it on your skin. I would suggest you practice heating, shaping and welding small pieces of ABS then work your way up to the larger project once you are comforatble
            MY INSTAllS:
            http://www.mp3car.com/vbulletin/show...e-install.html
            http://www.mp3car.com/vbulletin/show...tallation.html
              Fibreglass = Dust
              ABS = Highly toxic fumes
              Personally I'd rather take on fibreglass any day and use a dust mask lol.
              Fibreglass isn't hard to use either, just build it up slowly, I would say ABS would be harder to handle using a heatgun.
                I had a friend who would fab plastic in his home oven for simple shapes. If it is a continuous curve, not a compound one, you can build a wooden form and lay the plastic on top. Then, turn the oven on and find the temperature that the plastic softens. Took some experimenting to figure that out.
                Then, put the plastic over the mold, put it in the over until it softens, then pull it out and clamp it securely into position. When it cools, it hardens to shape.
                Want to:
                  Yeah, you can youtube vacuum forming and get a lot of DIY solutions just using an oven and a shop vac. However, large pieces are awfully difficult, especially for a first timer.
                  I always like forming something out of high density foam. Hot knife cuts off large chunks, then just a sanding block goes and does the rest. Stretch some fabric over it when you're done with some 3M adhesive spray.
                    Originally posted by TheGuv View Post
                    Fibreglass = Dust
                    Toxic fumes if you set it on fire, the heat gun is to soften the ABS, Obviously you have never done this so thank you for the input
                    It does come down to preference, however if you have never used ABS or fiberglass for that matter, you will almost every time have a cleaner install using ABS versus fiberglass... Years of personal experience speaking... you might as well tell him to do his install in carbon fiber!!!
                    Like Bugbyte said, little experimenting always does the trick, its all trial by error a learning process
                    MY INSTAllS:
                      I repair bumpers (plastic weld) all the time mate, unless you work with plastic all the time and know what you're doing you're gonna get some fumes. You dont need to set something on fire to get fumes LOL.
                      You can use an epoxy resin, it'll be far easier. Theres certain resins that you can prepare in a metal baking tray, wait for it to nearly set then you can cut it and mould it very easily, its like sliced cheese but thicker and more flexible- Very easy to handle and sets solid or have a slight flex depending on what you use.
                        Right, but thing is, I don't need to mold the curved piece-- I pulled it out of the dashboard, cut out all the vents and buttons and the clock, and all I really need to do to it really is neaten out the edges and add the semicircular tabs. It's the bit behind it-- the part I colored yellow-- that I need to fabricate. That's going to be just a simple box that will be hidden by the iPad most of the time, so it doesn't even need to look *perfect*. Its main function is to provide me with a place to put the displaced hazards, vents, defogger, and clock. If I ever need to access any of those functions, all I have to do is pop the iPad out of the dock.
                        I'll probably use a soldering iron and just melt the ABS sheets together from the back. Or now that I think about it, I can probably just use L-brackets and superglue them to the ABS sheets from the back. As for the semicircular tabs, I'll probably have to mold them out of bumper repair. Even if I could mold them to match the curve of the trim piece, I don't know how I'd attach them without having depressions in the plastic from the soldering iron.
                        EDIT: Reason I'm not making an entirely new trim piece is I want to reuse the original tabs, for ease of installation and removal from the dashboard.
