cut to size plastic
  • cut to size plastic
    Anyone know of a cheap online supplier that ships cut to size plastic? The only good one I've found is tapplastic.com, but I was wondering if there was any other cheap supplier.
    is there a reason you need it precut? i haven't looked in a while, but thought you could get bulk sheets pretty cheap when compared to them custom cutting it...
    next project? subaru brz
    carpc undecided
      I just figured getting them laser cut is the closest cut you can get and its hassle free. I was thinking a small mini itx computer case from plexiglass for my car.
        I have to admit, I got a little chuckle out of a guy named "kasemodz" asking where to get pre-cut plastic. Having never tried to cut acrylic myself, I digress....
          it is a little funny
          i can't say i have ever seen the edge on laser cut plexi, so not sure on the end result, though i have cut lexan, and plexiglass, and neither are too bad-- lots of small bits flying everywhere, and if your looking for that glass edge, it can be tough-- it takes lots of sanding and plastic polishing to do(if this is what your looking for, double check with the company that has the laser cutter)..
          if you have a band saw, that seems to be the easiest way to get to start to get a professional looking cut, though i usually end up using my dremel with a 1-1/2" saw blade on it...
          carpc undecided
            if you're cutting plexi or acrylic and want to get a clear edge you can simply take a blow torch to it after cutting... You have it keep it moving or it will catch fire. Also where a fume mask. not just a dust mask. it will melt the sand/saw grooves smooth like the face.
