fiberglass sunroof replacement
  • fiberglass sunroof replacement
    I'm wondering if the best way to get my solar panel on the outside of the car is to replace my sunroof glass with a custom fab'd fiberglass roof where I can mount the solar panel without drilling holes in my roof or otherwise damaging my car.
    In my mind, I could remove the rubber lining around the glass and make a clay mold. Once the clay dries, I can remove it and use the mold to make the fiberglass roof. Am I on the right track? I'm a major n00b to this fiberglass fabbing thing.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Scratch the clay. I think I"m going to go with a fiberglass mold and a carbon fiber sunroof.
    Here's my initial plan:
    https://docs.google.com/document/d/1...WK_jecE38/edit
    Can I use the carbon fiber resin/hardner for the fiberglass as well?
      Carbon fiber uses a different kind of resin than fiberglass. I forget the type you need, but it is pricier. Check websites that specifically sell carbon cloth. Maybe shoot an email to be sure. A concern I would have with the CF roof panel is that proper carbon construction requires an autoclave and repairs are a nightmare. Fiberglass cloth, instead of mat, should provide an equivalent result with a much better do-it-yourself attainability.
      Sent from my SCH-I510 using Tapatalk 2
        Ryven, you live just across the bridge from me (Hillsboro, OR). Good to know there are a few more NW peeps in this forum.
        From the vids I've watched on youtube, CF doesn't look all that much different from a fabrication perspective than fiberglass. Are you saying an autoclave is required to make the cloth, or to make the component from the cloth?
          you should look up what a autoclav does
          it's really only for using pre-impregnated carbon fiber cloth, and in a use that will rely on the cf for the structural integrity of the part(like a race car's pure-cf front end that applies hundreds of pounds of downforce to the car at speed).
          though i agree, unless weight is a major issue, or you really want the cf look, cf is really not needed for this application.
          fiberglass would be a lot cheaper, and still have the structural integrity you need for a panel like that.
          next project? subaru brz
          carpc undecided
            I do like the look of CF, but I think I can find black fiberglass and maybe save some money.
              Actually moving back over to Tigard next month. We should definitely meet up some time.
