2002 Chevy Silverado 1500 - bezel
  • 2002 Chevy Silverado 1500 - bezel
    Been reading the forums and in 1-2 posts I've seen something about 2003 Silverado 2 din bezel fitting on 2002 Silverado 1.5 din bezel. But I wanted to confirm it.
    So, this is the 2003 Silverado 1500 2 din dash should it fit into 2002 Silverado 1500 1.5 din dash?
    Can anyone confirm this?
    Also, has anyone tried using this Overhead Console to move the A/C and heat controllers? This way it would open open up a lot of opportunities for an install.
    I don't think that will work. I know there isn't room for a 2 din display where the stock radio goes, I have a 2000 Silverado, and it has had every setup under the sun. I'm currently using a MEMO 7" touchscreen display with a clever mounting system as my screen, but it took some work to make it usable. You won't be able to fit a screen that size in that slot without either moving your A/C, cutting up your bezel, and creating a lot of work for yourself.
    Moving AC overhead would be work, but doable. I installed power windows in my truck and put the controls up there, but it takes some work to make it look clean.
      See this is the tread where it says that there is room - link. They say it will, I'm gonna have to go to a junk yard tomorrow to see.
      Never took the bezel off, does it just pop off or does it unscrew?
        I read it a little different than you. I'm not sure he's talking about the bezel but to me it sounds like he's talking about the mounting bracket for the radio itself. This opens the whole inside the dash to a bigger opening to put the double din in. The you still need to do something with the bezel.
          Went to the junk yard today, picked up 2 din bezel from 2004 Silverado 1500, $15.00!
          The 2 din bezel from 03-05 Silverado 1500 definitely fits 02 Silverado. The climate control is a bit to high, so it leaves a hole. I'll take some photos tomorrow.
          But I'm thinking going back tomorrow and picking up the whole inside, where the stereo and and the climate control go. I'm guessing it will fit as well.
            If anyone interested this guy actually has videos on youtube on how to use 03 bezel on 01 Silverado:
            http://www.youtube.com/watch?v=cbybEFH3cgg
              The video show it all. I was going to tell you earlier today that it definitely has been done before but I was busy at work. I have an 02 avalanche and I did that before I decided to move my A/C controls to the upper console as you suggested to fit a bigger screen.
              As far as your questions about the A/C control goes is this what you had in mind?
              2002 Chevrolet Avalanche
              Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
              http://www.mp3car.com/show-off-your-...avalanche.html
                That overhead console does look great, I'm not that talented to do such thing. So, you just cut the the connectors from A/C and extended through the sides of windshield? I saw in your worklog the connectors hanging.
                Wondering if I can just use 03-05 A/C control unit in my 02? Have you looked at that? Maybe match the wires?
                See, I'm only looking to put a 7" or 7.7" Samsung Galaxy 2, from Verizon. So, I don't need a lot of room.
                  What if I told you that this was my very first attempt at fabricating anything? Before this piece, I had never used bondo or fiberglass or any of that stuff ever.
                  It took me a whole year to work up the guts to do this. I even purchased a separate overhead console and a A/C controller in the event I messed things up.
                  As far as the controls go type of control go you have to verify if you have automatic climate control or not.
                  If you are thinking of using the digital versions on the 03 - 05, you're out of luck.
                  It has never been done and it never will because the work involved is just too much.
                  I have done the research and I'll tell you this. The whole computer data bus for both systems are completely different. Not only will the wires not match but the whole wiring harness is different and the color coding is not the same.
                  In addition you will need to reprogram the car's different BCMs and a whole lot more. It is definitely not worth the amount of work involved.
                    Id say gimmie your address and I will send you one for my 03 Avalanche so you can take care of it for me.. Actually if you have a console like that I could just send you some controls and you can use your spare one..
                    Rodney
                      Rodney
                      I will probably consider it during the summer months. Emphasis on probably.
                      I am not a pro at this yet.
                        I'm going to the junk yard tomorrow, but from what I've seen the controllers from later years aren't digital. Look pretty much the same as mine. I didn't check the back of them but you're saying they can't be rewired wire for wire if they're not digital?
                        I wish they showed the back here - http://www.ebay.com/itm/390532515474
                        This one does look different - http://www.ebay.com/itm/160961559762
                          Actually the controller look just like mine http://www.ebay.com/itm/330702487102, but this is from 2003. The only thing I don't have is the rear defrost.
                            There are 3 variations of the controller on the later models the one that looks like yours is actually a carry over from the 02 models.
                            There are very few of the earlier models that have that.
                            Look closely at that picture because folks can get them mixed up.
                            There is this one
                            :http://www.ebay.com/itm/99-02-Tahoe-...30702487102%26
                            and this on the 99- 02 models
                            http://www.ebay.com/itm/330702487102?afsrc=1#vi-ilComp
                            One has automatic climate control whereas the other does not.
                            You cannot see the back but the plug is different and the systems are built and work differently so even those two are not interchangeable.
                            For one thing the automatic versions will not under any circumstances turn on the A/C for heat exchange if the outside temperature is below 40 degrees Fahrenheit.
                            The manual version will though. What I am saying is that there is more logic built into these individual systems that just trying to match the wires will not work even if you could figure out to match all 31 wires that are found in the back of mine.
                            Moving on the the digital versions.
                            I did not mean the A/C was digital but rather that the controller as a digital display for its functions as evidenced by the LCD screens
                            Those also have a different set of logic that will even need to be programmed into the cars computer.
                            Another thing is the wires themselves.
                            I am sure if you were to pop the wire harness plug of the controller , you wiil find that the number of wires that are there is less than the total number we saw on mind.
                            That means yo will also need a new wiring harness and be able to take your dash apart to run it in the dash like the factory wiring. Thi is just the tip of the iceberg.
                            Wish you luck if you ever find a means of swapping it out
                            C ss
                              Dluvr22, can you just post the Ebay item numbers, for some reason they're not going through on the link. I wanted to see the difference.
