Upholstering with vinyl?
  • Upholstering with vinyl?
    Hi guys,
    I'd like to upholster my monitor pod with vinyl to make it similar to my dashboard. I made the pod out of fiberglass, here's my plan for coating it:
    1. I'll spray the pod and 1/2" dense foam with 3M #77.
    2. Wait a few minutes (as per another thread)
    3. Put them together.
    4. Do the same with the top of the foam and the vinyl.
    5. Use a heat gun to help stretch the vinyl around corners and curves.
    Does this sound right? Will the 1/2" foam work?
    Chrysler 300 - Fabricating
    http://hallert.net/
    Ive never really seen it done so I got no help for ya, but I do have a question. How well does vinyl cope withy corners and curves? just using the heat gun and stretching will that be able to prevent bunching on corners n such, most importantly in the inside radius of curver.
      I'd like an answer to that too, if anyone who has done this knows....
      http://hallert.net/
        what is the purpose of the foam? that is the only part of your setup I don't get. I've wrapped a couple things in vinyl, and your best bet is to spend a little more money and get vinyl that is marketed for car audio applications because you know it is going to stretch nice. use spray adhesive, and just work your way around the pod stretching the vinyl the best you can. heating it really helps, just don't go too crazy with it. like I said, i dont really understand why you are using that foam- you're gonna have tons of problems with stretching the vinyl evenly over the foam unless its like 1/16" thick or even less. If you're worried about getting the vinyl to look smooth, i'd be more worried about getting that foam to lay well. i know at craft stores they sell those colored sheets of hard foam, is that what you mean? maybe i'm just confused...
        02 LEXUS IS300 // MANUAL // HKS // PLP // AAC
        itunes carputer in the works
          i've wrapped a few dashboards with vinyl, it takes a few minutes to get used to, but wraps well with a heat gun. I have seen vinyl with foam already attached (to give it a more plush feel), you may want to look for that.
            I'm using the foam to get the plush feel, and it's just 1/2" thick.
            http://hallert.net/
              i would like to see the vinyl with foam already on it. I have been wanting to do my dash and having that would make it look great!
              Randell Kelly
                can somebody post some pics of material we are talking about here, please?
                  all I can say is you better have a keg laying around...
                  I have 2...
                  Originally posted by menudude
                  thank you all for your help minus the useless post by sjlucky...
                    Use 3M#90, this is the best spray glue. You can also use contact cement, found at any home improvement store. You will have to fasten the edges well, either using staples of super glue especially if you heat it up and stretch it. Once vinyl is in place, make slices with a razor blade at the edge of the material, stopping just short of the edge. You might have to overlap these "fingers" or small flaps to eliminate wrinkles, then staple in place. Before you wrap it, Make sure the surface of the piece you are covering is as smooth as possible. The vinyl will expose any pits or bumps on the surface.
                    Pics of vinyl:
                    http://www.selectproducts.com/product/fabric.htm
                    WORKLOG
                    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
                    Webpage
                      You want to use the white closed-cell foam thats used for vinly tops on cars. I would go with either 1/8" or 1/4" foam. I think 1/2" will be too thick. I've used this foam to make designs in custom door panels and it works great. Just go to any shop that does vinyl tops and they'll sell it to you. You may be able to get a few scrap pieces large enough.
                        I did the enclosure for my first system that way. I found the vinyl that matched the dash in texture and color. 1/2" foam will be way to thick though. I used headliner material that I found in the store where I bought the vinyl and applied it first then covered it with the vinyl and it made it plenty soft.
                          check this site out for auto vinyl. They have lots of kinds and colors with all kinds of assorted grains.
                          I have bought from these guys twice (i bought carpet there) and have been pleased. Very fast shipping too.
                          http://shop.store.yahoo.com/yourauto...tore/auto.html
                          They also sell foam
                          http://shop.store.yahoo.com/yourauto...ptingfoam.html
                          Car: 2000 Audi A4 Avant 1.8t
                          Carputer 2.0: removed. Back to stock.
                            Yeah, 1/2" WAS too thick. Started over, will post photos when done.
                            WAY too thick, looked like my enclosure was a stuffed animal.
                            http://hallert.net/
                              http://shop.store.yahoo.com/youraut...store/auto.html
                              and http://www.selectproducts.com/product/fabric.htm
                              Great links. Thanks moltensilver
