Designs for slide in/out screen
  • Designs for slide in/out screen
    hey, just wondering if you guys can post what you have/seen or planning to do to make the enclosure for the screens and specifically, for being able to slide it in/out.
    So far i figured i can make the roller part fairly easily using some plexiglass, which will give me the horizontal movement for the screen. But now I'm stuck on the vertical part, just not sure what would be a good design for being able to angle the screen.
    Here is what i'm talking about:
    where the (-'s) are the rollers to provide the horizontal movement and the (||'s) represent the screen.
    Any help would be appreciated!
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    what about a hinge that runs the lengthe of the whole setup that tilts up 90 deg:
    ||||||||0---------
    0-----------
    where - is the rollers
    || in the first design is the screen,
    = is the hinge, with the joint being 0
    Cheap Laptop, great for Carputer!
      That is the most obvious solution, question that comes to my mind is how to lock the hinge securely and at the same time make it so it's easy to fold it down also.
      VIA Epia II
      256MB 266DDR Ram
      90GB Wester Digital
      Bluetooth/Deluo GPS
        Anyone know any sources for a 90 degree lock hinge? Because that would solve all the problems on the spot!
        VIA Epia II
        256MB 266DDR Ram
        90GB Wester Digital
        Bluetooth/Deluo GPS
          another hinge type option:
          I've taken old laptops apart before for parts. The hinge on the screen is just a little thing that looks kinda likd this: __==__ (where __ is a flat part with screw holes and == is the round hinge).
          with the right leverage (the laptop screen) they open and close fairly easily, and hold the screen in whatever position you choose. separted from the screen, without leverage, you cant even turn them with your bare hands. takes 2 pairs of pliers and a good amount of effort to move them.
          anyway, just thought that a couple (or even one) of those would make a good hinge for it. I can take picture of one and post it if your interested.
          2000 Jeep Cherokee
          -CarPC: [_____]50% complete
          -planning done, still need a few parts
          -In-dash motorized VGA is finally out, need $$$
          -Need to replace factory HU
            yes please that's exactly what i'm looking for! now just gotta source them from somewhere.
            VIA Epia II
            256MB 266DDR Ram
            90GB Wester Digital
            Bluetooth/Deluo GPS
              how bout dead laptops?
              it seems you would want more resistance then less in the car...
                I'll post a pic late tonight when I get home.
                Dead laptops is where I got my 4.
                depending on how its setup, there might even be too much resistance in them, kinda thing you would just have to try... plus each pair is a little different.
                2000 Jeep Cherokee
                  Problem is, i dont have too many dead laptops lying around here! Time to call some laptop repair stores.
                  VIA Epia II
                  256MB 266DDR Ram
                  90GB Wester Digital
                  Bluetooth/Deluo GPS
                    heres a pic of the two that i have. actual hinge part is very small, however most of the metal is needed to securely attach the hinge to the assembly, because there's alot of stress put on the joint.
                    2000 Jeep Cherokee
                      thanks! now to find one.. this is probably going to be the hardest part of this entire project. I need to fiberglass a mold of my glovebox door/remove the door replace with the fiberglass part fo hide the screen and than somehow make it slide out. ugh! lol.
                      VIA Epia II
                      256MB 266DDR Ram
                      90GB Wester Digital
                      Bluetooth/Deluo GPS
                        How about these? http://cgi.ebay.com/ws/eBayISAPI.dll...479510650&rd=1 Not my auction. Sometimes I have seen them for $5 a hinge or less.
                        Ted
                          That would be great. If it wasnt US shipping only Now do you think just one hinge will hold the screen fine?
                          I'm guessing it shouldnt be a problem..
                          VIA Epia II
                          256MB 266DDR Ram
                          90GB Wester Digital
                          Bluetooth/Deluo GPS
                            y not just mount 2 other hinges either side for stabilty/strength and use the laptop hinge in the centre....
                            my NZ$0.02
                            92 Subaru Legacy Wagon
                            Epia MII12000 :D
                            Morex 80W
                            120G External HDD
                            16x2 Charater Display
                            Creative IR Remote
                            VIA Sereniti 2000 Mini ITX Case
                            7.2Ah SLA Tank
                            PCMCIA 802.11b
                            256DDR Ram
                            Diamonds are for girls- wise men follow the stars
