plastic/rubber coating my glovebox
  • plastic/rubber coating my glovebox
    Hi,
    I want to setup my carputer into my ever so tiny glove box. The VW Jetta glovebox is lined with this sort of felt like material that does not just peel off. I suppose if I sanded enough I could get it all off and repaint.
    But what could I do to plastic or rubber coat my glovebox so that nothing will short out (static electricity). Can I somehow fiberglass the inside and repaint or, I'm open to suggestions.
    Thanks,
    samc
    Mine needs to be updated.
    hey buddy
    i had my carputer installed in the GB of my A4 for a while, and i know what you mean about the lining. What did was just mount the mobo on a thin piece of wood with standoffs and i had no problems with static. Not sure how this might help, just saying that it might not be as bad as you expect.
    you could just paint it.......that might take care of any static stuff you might have. dunno....
    Cheap Laptop, great for Carputer!
      you can use a can of spray rhino liner. It's truck bed liner in a spray can. It will have a slight texture to it though.
      If at first you don't succeed, so much for skydiving!
        Thanks Dr Jeckyl.
        Jusatry can you hit me with some pics of your glovebox setup. And what do you mean by standoffs? Maybe I am thinking more into it but you know I'd have to goto my car one morning and see my board all roasted (pun not intended).
          re:
          Originally posted by samc
          Thanks Dr Jeckyl.
          stand offs are those little brass things that u usually screw into your case... then on the other side there is a threaded hole (so u can screw teh mobo to the top of the standoff....)
          heres 2 pics i found from google http://www.reality.net/case/photos/standoff-1.jpg
          http://biorobots.cwru.edu/server/how.../standoff2.jpg
          they just stand the mobo off the surface of whatever they are attached to...
          AT mobo
          Intel Pentium MMX 233mhz
          ESS Solo PCI soundcard
          Linksys NIC
          Irman
            Thanks toadster123, all these years it didn't occur to me that those little things had a name, I used to call them "those metal things you screw down a mobo with"
            But jusatry Id still like to see a picture.
              Go to TAP Plastics and get some of that Plasti-Dip stuff. You know, the stuff you dip an old set of pliers in and it puts this rubbery coating on the handle again?
              Pour that stuff all over your glove box..
              VOILA!
                closed cell foam rubber....for example old mouse pads?
                  samc
                  my setup has since been uninstalled and i didnt get any clean pics
                  ill see what i can scrounge up, but till then let me describe it:
                  the mobo was mounted to a piece of hardwood which had 2 legs on one side and none on the other, thus standing it at about a 30 deg angle. that way the door to the GB did not interefere when closing. to the underside of the wood i mounted a laptop HDD - so i could use the short casetronics IDE cord. then in the din slot above the opening in the GB i put the slim DVD drive and the m-audio sonica theater card. all the wiring (atx, usb, VGA, etc) went through the perforrated hole in the back of the GB where the A/C is supposed to go. the PSU was mounted with the shutdown controller to a piece of wood which fit in the double din slot, with the lilliput as the front.
                  hope that helps, feel free to post or PM with questions.
