Tips for Mounting a Lilliput tft in a Bmw 535i -92
  • Tips for Mounting a Lilliput tft in a Bmw 535i -92
    Hello there!
    I think the placement of the tft is best between the shift gear and the black panel and its much more discreet.
    Look`s like its the only place i can put the tft though.
    Have been reading some about the bondo and the fiberglass..
    Maybe a wodden frame 1st as a ground structure?
    Really want it to be intregated as a part of the car and looking real nice
    Any comments or tips is welcome
    Ampie Case
    M1-ATX 90w
    EPIA ITX 1,3Ghz, Firewire
    80 GIG SATA
    512MB
    7 TFT Touch Super
    Pioner Slot in DVD-RW writer
    108 Mbit Wireless Lan
    100 M Bluetooth Range
    //Power Nisse
    My Betasite -> http://haagen.se
    yep, use wood for the basic structure and fill it in with bondo...shouldn't even have to worry with fiberglass if you have enough structure with the wood
    CarPC install is starting to come along again...
      OK, that might work.
      But what is bondo in swedish.. so i know what to ask for
      Checked the placement for the screen Hmm.. look likes the 8 tft is to big
      and its nicer with a wide screen so i think im gonna buy the 7 tft touchscreen
      But the damn shift gear is right in the middle of the screen
      Maybe gonne replan this project afterall
      Ampie Case
      M1-ATX 90w
      80 GIG SATA
      512MB
      7 TFT Touch Super
      //Power Nisse
        Bondo in Swedish, isn't that allmost the same as in Norwegian?
        Bondo=sparkel (spackel)
          Bonbo in Swedish is Bondo. It's a brand name. It's also called 'auto body filler', 'all purpose filler' and 'all purpose putty'. If you translate any of those last three phrases into Swedish, someone at a hardware store should know what you mean.
          Good luck1
          2004 4runner
            Aha.. of Course "spackel"
            well im planning of starting with a wooden frame end then use some bondo..
            It`s a real pain in the *** to know how to put the screen and make it look good.
            But im gonna experiment a lot
            Ampie Case
            M1-ATX 90w
            80 GIG SATA
            512MB
            7 TFT Touch Super
            //Power Nisse
              Has anyone installed a screen in a 89-95 BMW 5 series?
                i have, where do you want to put the screen? theres not alot of room where the stereo goes maybe below a t anangle in the center console.
                Ohh and the problem with just using bondo is if its to thick (more then 1/8 inch) its probley gonna crack. use fiberglass then a bondo fiberglass mix. i just wrote about it here http://www.mp3car.com/vbulletin/showthread.php?t=14036 on the last page
                  I'd like to see if a screen will fit in the center console at the same angle. Got pics?
