Glossy Finish on Fiberglass / Bondo
  • Glossy Finish on Fiberglass / Bondo
    After reviewing some pics i took at a show last fall here in Toronto i got a question... Does anyone know what kind of finishing products/prepping work needs to be done to achieve a glossy finish on the fiberglass parts?
    Obviously the surface needs to be prepped/sanded very well to achieve a smooth look so glazing putty is our friend there. However, what's after that, do you apply the paint and than some kind of paint over it to get the gloss.. or?
    Here is a picture of what I'm talking about if I'm not clear:
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    It's done by getting the surface smooth, then priming, then spraying down a few layers of paint, then color sand with a hi-grit wetsand paper, then an automotive-grade clearcoat. Let it dry, wetsand, then a few layers of clear, and it's done, with a very sore arm from all that sanding, trust me.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
      Ahh! My original plan was smooth > prime > spray. done. This will extend it by a few steps.. sheesh.
      Few questions. Color sand? Wetsand paper?
      VIA Epia II
      256MB 266DDR Ram
      90GB Wester Digital
      Bluetooth/Deluo GPS
        Wet or Dry sandpaper, very fine grit above 1200 grit. it's black in color, and you sand, keeping the surface wet with water.
        Colorsanding: Basically wetsanding the several layers of color paint (or clearcoat) to eliminate "orange peel" or imperfections in the surface. Yes, it does scuff up the surface a little bit, bit the last coat of clear, and some buffing are what gets it glossy. Good link on colorsanding:
        http://www.customclassictrucks.com/h...37_0403_paint/
        The more sanding, and clearcoat with layers (and elbow grease) is going to give you a "deeper" glossy finish.
        WORKLOG
        Webpage
          *Enlightened* Thanks snootch
          This weekend is gonna be busy for me!
          VIA Epia II
          256MB 266DDR Ram
          90GB Wester Digital
          Bluetooth/Deluo GPS
            In addition, the Carsound Fabrication forums are a great source for knowlege on this type of stuff:
            http://www.carsound.com/UBB/ultimate...?ubb=forum;f=4
            Good luck on your project. REMEMBER: make sure each coat of paint has FULLY CURED before you sand/paint/buff on it.
            WORKLOG
            Webpage
              once you have all your fiberglass work done, all the painting/clear coats/colorsanding/etc...is there much maintence to keep it up? i'm sure its not as bad as waxing your car and whatnot due to the elements it faces, but still curious on how much work is needed to keep up that deep glossy finish
                Naw, just wipe it off occasionaly, and make sure no one kicks it, sets anything on it. Make sure that nothing is cracking or anything due to the sun, etc.
                WORKLOG
                Webpage
