Own Distrobution Block?
  • Own Distrobution Block?
    Whaat would be the best way to make a distrobution block for acessorys, say lights, lighted switches, radar detectors, psu, alarm, etc, etc/
    Crouching Tiger, Drunken Kitty
    Something wrong with the ones you can buy?
    They're quite a ***** to make if you want one that's safe.
      i would rather have 1 big distro block, then like 2,3, or 4
        Then buy one big distribution block.... Your not going to be able to fill up even two - 2 ga. spaces on a distribution block with all those 12-14ga. wires.
        An alternate solution would be to have a large 12v wire running behind the dash and just tap and solder where you need to get power to things. Tape the soldered areas with electric tape of course.
          well, i would like to have it sorta like a factory distro block, with fuses to each item
            Go to any boating/RV store, but a 12V fuse block (they make them as big as you'd ever want). That is what you are looking for.
            2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
              Painless wiring makes good products for what you are talking about.
              h**p://www.painlessperformance.com/fuseblock.htm
              The Ultimate CBCC?? (Clean Black Car Club)
              Click here for the Truth
