Having problems with paint-Weird frosting effect
  • Having problems with paint-Weird frosting effect
    Hi guys, I custom molded my lilliput into my dash using the original lilliput case and bondo. It looks really nice, I even put a DVD tray below the screen. The problem is, and I had it before when I tried painting a while back ago without the tray, is that instead of leaving a nice black paint finish it looks very hazy. Theres a lot of light grays in it. It looks kinda "frosty". When I get home I may be able to get a picture.
    I put "sandable filler primer" over my bondo when I was done and sanded that pretty smooth, then painted one coat and got this effect. Could it be the humidity? It was 57% humidity last night when I painted it at about 7:00PM. The temperature was decent, about 88 degrees. I'm thinking the weather isn't the problem. The paint I used was duplicolor universal flat black.
    Also, the paint is a bit "mushy" if you try to push it in unless you let it dry like overnight. I know this from it happening before. And I don't know how I managed to get it to stop doing that, I think I bought a different can of paint. I thought maybe you guys have had this weird frosting effect before and could share with me what you did to fix it. Sorry for the long post
    CarPC install is starting to come along again...
    When you say smooth, how smooth, what grit sandpaper were you using ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      That frosting or haze effect is common on wood finishing at that temp and humidity.
      TruckinMP3
      Read the FAQ!
        Smooth as in 400-600 grit. Not so smooth that the paint wont stick.
        Truckin: Is my humidity too much? The paint can said 92 degrees was the max temp, didn't say anything about humidity though. If thats the case then I'm screwed cause this has been the lowest humidity lately. Btw my dash piece isn't wood
          *bump*
            don't know if this will help but i went down to 1200 grit wet and dry paper on mine and it came out a lot better than my guide coat at 400 grit
              yeah, i planned on smoothing it more but wanted to see the guide coat...but my thing will have some texture to it, if you spray the paint in mists and dont put it on thick at all, and dont sand every time you paint you can get a nice texture on it which i like.
                oohh i see where you are going i just used texture paint, doesn't look as effective as the way you describe, but a lot less work good luck, you could try a few more coats from different angles might get rid of the frosty look, thinking about it it may be primer coming through the paint causing the effect.
                  nah it still does it with several coats of black paint
                    Originally posted by Grayscale
                    SNIP Btw my dash piece isn't wood
                    I did read that, I was relating to the humidity and finish to similar effects in wood finishing. I belive part of the issue is the humid conditions you are working in. I hope it turns out well for you.
                    TruckinMP3
                    Read the FAQ!
                      do you think putting it in a room with a dehumidifier would help ?
                        Maybe, it will not 'hurt' it it. Mostly we do not have high humidity problems in Colorado...
                        TruckinMP3
                        Read the FAQ!
                          its horrible in arkansas. i'm going to go to some paint shops around here and also try this body shop/paint shop
                            There are two types of paint.
                            I don't know the names of them in english.
                            I thought is had something to do with the lead in it.
                            When you mix these types up (using a primer of the first, and a collor of the second) you get this kind of troubles.
                            Did you allready think of that?
                            www.Carputerforum.nl
                              In the US you can not buy lead based paint anymore, Federal regulation prohibits it.
                              This has been true for years. You may be thinking of acrylic vs laytex.
                              TruckinMP3
                              Read the FAQ!
