anyone.. will these fit?
  • anyone.. will these fit?
    Ok these two items are slim fit
    the lili is 7 7/16 wide and 5 tall
    the width for the dins is safe. as i measured that
    since this liliput has a remot eim trying to figure out if i will be able to modd the screen so i can chop of the bottom few buttons and only need the ir sensor and the power button. ill use remote for rest?
    anyone know
    lilput ebay - anyone buy from him before?
    heres the din slot im concerned about. its a dual dint but with 0 room for play on top/botom
    auto toys din.. know of anywhere else to buy this for cheaper?
    thank you!
    I am gonna get my xenarc into a double DIN if it kills me! If you look in the "Show off your project" forum, you will find a seat LEON in there, has fitted the lilliput into a double DIN so depends on your car i recon, and how much room there is behind the console.
    I believe a DIN socket is
    60mm high x 178mm wide
    therefore making a double DIN
    120mm high x 178mm wide
    So, with a bit of widening (is this a word lol) of the gap my 195mm xenarc will fit and height wise only a couple of mm out. (Xenarc is 122mm high)
    Good luck, and let me know how it goes!
      bahh humbug
      i think ima go with a indash in the bottom slot and leave my head unit alone... for now
      we will see where i got form there. but this will let me install my xbox. mwahahahahaha
