Buttonless Lilliputs
  • Buttonless Lilliputs
    I want to install my lilliput without any buttons. Beyond doing the auto-on mod, what else would I want to do to the screen to make it so I don't need to push any buttons on it?
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    if going buttonless make sure the infra red eye is still usable, there are times when you need to "set some screen parameters"
    the infra red eye is pretty easy to desolder from the buttons pcb, which must still be connected to the screen but can be left dangling inside the housing, I used an audio cable from a cd rom to extend the infra red eye on my buttonless setup
    good luck
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
      you're right. I forgot about the remote.
        i covered up all my buttons and just left the infared beam hole. its way cleaner wtihout the buttons...
        kinda lost the little covering thing for the infared hole, gotta find it, haha.
        2003 Nissan Pathfinder LE - My cardomain page.
          If you do the auto-power on mod, this would work great - no need for any buttons, though making a window for the IR sensor is a good idea. I used part of an RJ45 jack to make a window in the bezel I made for the Lilly - works great and looks pretty good
          "Protecting Privacy and Free Speech Online"
          http://www.eff.org/
            I made an extension for the power button so I can turn off the lilli a few blocks before I park (also with the coyote mod). I used a tiny bush button from Radioshack that just happened to match my dash perfectly, rendering the button completely invisible. This, I think, is just as important as concealing your screen.
            Also, I don't even have the IR sensor visible. I was planning on drilling a small hole for it or something, but it turns out that I never use the remote anyway.
              Any idea on how to make a sliding door or some other device to be able to conceal the screen?
              BMW 325i -01
              Computer hardware:
              VIA Epia MII 10000 Nehemiah 256MB/160GB
              Casetronic Travla C158
              Gain 7" TS
              USB GPS
              Opus DC-DC 150W
              Software: Frodoplayer and Mapmonkey
              Sound system: Front kit: DLS UP6, Rear: DLS 425 Powered by DLS RA40
                using an actuator or a low geared motor and some sliding tracks. http://www.selectproducts.com/frames.html
                  Most of the good actuator I have seen are expensive. I'm tring to figure out how to do the samething. I'll let you guys know how I implemented when I get done with the cover/door.
                  Installed
                  Asus A7N8X-VM - AMD Mobile Athlon 2400
                  512 Ram - 60GB HD - Opus 150w
                  Lilliput 7" - Rikaline 6010
                  [00000000000001100010-] 98% Completed
                  Check Out My Install!!!
                    i think an electric motor would work better for something like that... actuators are good for moving heavy stuff, an electric motor is fairly cheap, and would give that slow fluid movement that would look pimp.
                      you could probably yank a few from some old stereos that have the remote knobs or something of that nature. Then again, you could just make a sliding door with some resistance, somewhat like a breadbox.
                      Then again, I hate bread. And it wouldn't look as cool.
                      (\__/)
                      (='.'=)This is Bunny. Copy and paste bunny into your
                      (")_(")signature to help him gain world domination god I can't believe I did it...
                        there was a thread about this somewhere on here and if you guys look at the new scion tc it has a cover over the cd player that you can open and close.
                        my idea was kind of like yours but the problem is space and geting the cover to fold for a flush look when its open or closed. i have been thinking insted of have the cover come out from the top or bottom of the unit why not have it coming for the side? or have a half come from each side having them to meet and sit over laping but flush at the same time in the middle of the area ? any one have any ideas how this could be done?
                        just a few pointers and thoughts
