Double din surround for Xenarc/Gain screen
  • Double din surround for Xenarc/Gain screen
    I have seen a double din surround for Xenarc/Gain screen somewhere (on here perchance?) but for the life of me can't find it again. Does anyone know what I mean?
    Do you mean something like what I made for my car??
    Rich
    http://www.mybimmer.net
      I've seen you creation already, and very good it is! 10 out of 10.
      But I saw something manufactured specific for the task, would be for a VW Golf MK IV. Where did I see it, I thought I saved it as a favorite nut no go.
        Is this what you want?
        Xenarc Headrest Shroud
        http://store.karpc.com/item-Xenarc-H...oud--700shroud
          Yea yea yea! You diamond geazer!
          But I thought I read somewhere this was for double din fitting... guess I was wrong.
          Thanks anyway, back to the drawing board!
            I don't think so.. A Xenarc with the houseing is big (height) enough to fit if a double DIN....With the shroud it won't fit at all!!
              That's OK, just get rid of drinks holder!
                Dude, the xenarc is SO CLOSE to fitting in a double din size.
                I have taken a Double DIN facia for my car, and have managed to use the above mentioned shroud to glue it to the facia. I am now in the progress of tidying up the glue-work and making it look stock.
                From my measurements and knowledge, i came up with this:
                xenarc dimensions:
                195mm wide X 122mm height x 35mm thick/deep
                (7.75inches wide x 4.75inches height x 1.33inches deep/thick)
                Single DIN = 60mm height x 190mm wide x 170mm deep
                Double DIN = 120mm heightx 190mm wide x 170mm deep
                So, the height is only around 2mm too big, and the width is only 5mm too big.
                Correct me if i am wrong, but with a little filing here and there you can get it in?
                I will keep peeps up to date on here with the install as it progresses!
                www.leoncupra.co.uk
                  an invader from the SEATCupra.net forums!!
                    Nice one Pabs, those dimensions refine the thought processes going on!
                    Yesterday I thought about getting two of the OEM Golf cubby holes and combining them to make a double din cubby hole into which the screen is fixed. The cubby holes will click into place within the fascia so easily removable.
                      Yes.... and? Been on here as long as I have SCN! (And icecavern, and seatowners,and digital-car.co.uk.....)
                      Lots of forums, lots of info!
                      Can u blame me?
                      lol
                      www.leoncupra.co.uk
                        I was only messing about m8, calm down.
                        Cant blame you at all, this forum is packed with info
                          you on scn too? If so, under what name?
                          Wasnt being arsey, but its damn hard to tell tone of voice i suppose
                          cheers!
                          www.leoncupra.co.uk
