baren lcd to fiberglass
  • baren lcd to fiberglass
    ok im making my bezel for my camry(winter car) and well i cant use the housing it cam in becasue the whole housing is way too big to fit in my double din slot. do i need to make my own bezel out of fiberglass. heres where im stuck at how do ppl make such straight housing lines? and how do u connect the lcd to the fiberglass. the lcd is a touch screen so it would have to be secured very well so i can press the screen andnot fall back. any help would be nice, thanks in advance. sam b.
    Best Technique In Life Is Having No Technique
    ONE DAY I WILL LEARN HOW TO USE THE COMPUTER THE RIGHT WAY.
    what kind of screen is it?
    secondly...I'm in a similar position cause being a dummy I accidentally destroyed the case/bezel for my screen so I have to fab a front one for now...what I suggest is using the front bezel..and molding that into the dash...then use either metal strap or be creative to find something to use to hold the rest of the screen
    http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
      the screen is a starvision t700ts but i cant use the bezel it came with. it wont fit in my dash. and i tryied to make it fit but i end up with small strips that wont work.
        you cant hack the bezel and part of your dash so you can keep the retaining clips (where to screw in the LCD) ???
        Kinda like what i did... check it out http://filebox.vt.edu/users/avanderb/RSX/
        go to the LCD, granted its in an RSX but something along those lines of kinda focring it to work and f/g around to hold it and build it back up.?
        Apolo
        sorry had a typo in the link... its fixed now
        2002 DSM RSX-S
        Custom Car PC Re-design Pending Completion of fiberglassing dash and trunk
        Pics
          interesting....I think I may have the same screen...well I'm going to be making a custom bezel and mount for mine as well..can you post pics of your screen and dash?
            Hooah!! Another Camry Man!!!!
              ok the reason i cant use the bezel it came with is becasue i would have to cut it soo much their are no screw holes. heres a few pics of the bezel that the lcd came with and how it over laps the stock loacation.
                I see what you mean...looks like you've already modified the bezel...also where are you planning to move your buttons to?
                I have the exact same screen...and I'm unsure what I want to do at this point as well...thinking about just fabbing the screen into the dash and then mounting the buttons into the dash panel, just not sure I have the right tools to cut out the correct openings for the buttons.
                you've got a PM btw
                  nah i just touhgt about it. im going to make my life alot easier and just going to resolder the ir eye. and mount it to a different location and make it look clean.
                  i was doing a search to see if any one had a auto on but no one has tried it so ill do the next best thing. plus i would be best to still be able to control the unit and get to the other 2 channels. seing gow i have 1 rear view camera thats just a rca hook up.
                  i also replied to ur pm oekundar
                    It looks like you got a Gen 3 camry right? What other mods do you have? Also are you part of TN? or SC3?
                      no mods thats my family car aka winter car, so its maninly untouch. i have a supra aka black whole of endless moneypit. and its a 3rd gen camry not on any forums for it. im mainly on supramania or supraforums, same screen name. sam b.
