Plexi / Acrylic Woes
  • Plexi / Acrylic Woes
    Im going to be mounting my car pc in the floor of my van in the back
    ive already fabricated a box 2" deep 15" wide and 35" long.
    I originally planned on using .5 (half inch) plexi glass to accomplish this.
    after doing some research i found that i have to buy a whole sheet 4'x 8' which would set me back 210-220 bux.
    I could use two sheets of 1/4 inch but im not sure that will support the weight of someone nor am i even sure the half inch will. anyone fabricate something similar to this?? or have any suggestions?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    use lexan or layers of it... it is almost bulletproof....it won't crack like plexi
      maybe make some kind of support brace in the middle just to take some of the weight.
      where in long island are you from? you should come to the next meet
      rebuilding carpc... kinda..
        hey joel
        Where would I find lexan? is it clear?
        and most impotantly would i need a full half inch of lexan or would 1/4 suffice
        .______
        | '_ |__\___
        [(o)|___(o)] XB
        ._________
        | I__I I_I|_\__I
        CarPCNetwork
          suffolk county
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          CarPCNetwork
            where abouts? im in huntington. lexan is clear but might be more money than acrylic
              yea im close to you im in central islip ...yea i just checked the prices on lexan its lke $135 for 1 24x48 sheet ouch
              i know someone on here must know if .5 half inch is thick enough
              .______
              | '_ |__\___
              [(o)|___(o)] XB
              ._________
              | I__I I_I|_\__I
              CarPCNetwork
                15" wide and 35" long lexan?
                you want this just to hold itself up- probably
                you ever gonna lean on it?
                  give Hindricks glass a call there located in mt. sinai, i got a big piece of 1/2 inch acrylic from them awhile back(about 12x30) if i remember right, it set me back maybe 30 bux
                  Ill see if i can find the number later
                  amd 1700, biostar m7ncg 400, hitachi deskstar 120 8mb , 512 pc2700, liliput 7"
                  now to put it all together
                    sweeet thx man ill call them 1st thing tomorrow
                    is this them Hildreths?
                    yea most likely from time to time someone may get in the back of the van so id say it may have to support up to 180 lbs or so my friends dont weight much and no fattie girls in the van lol
                    .______
                    | '_ |__\___
                    [(o)|___(o)] XB
                    ._________
                    | I__I I_I|_\__I
                    CarPCNetwork
                      yea, its hildreth's, my bad
                      you want the glass and window shop, they have 2 shops one does auto and the other does reg. windows and such, it the shop on the right when you get there. give them a call first and make sure they have what you need. if they dont have it try calling some other glass and window shops, most places carry stuff on this size or are able to get sheets that big and wont rip you off(look under glass and window shops in your area if this is far from you, they just happent to be close to me and Ive used them before and was happy with what ive gotten from them)
                      go w/ the 1/2 inch acrylic, it will be more the strong enough(i have a 225 gal aquarium made of 1/2" and it will take a beating) acyrlic will be more resilient to impact hits where lexan may brake(im talking vibrations and such), also lexan always seemed to have an off yellow color to me, its also easier to get scratches out of acylic then lexan in my opionion.
                      The number for the glass shop is
                      928-1245
                        so the glass shop is in mt sinai? the website says pt jeff they have 2 offices im assuming?
                        [Edit] must be port jefferson actually [/edit]
                        .______
                        | '_ |__\___
                        [(o)|___(o)] XB
                        ._________
                        | I__I I_I|_\__I
                        CarPCNetwork
                          1/2 would be enough for sure.......they have many different colors. Scratch resistant, etc....
                            Looks like they may have moved offices, Yes this is the place. Port Jeff station and Mt Sinia are next to each other, the old location was on the border of the 2 town's,
                              unfortunatly they didnt have it tho iwent to some other place they didnt have it either so im going with 3/4 in hopfully this will look ok thx for the suggestion
                              .______
                              | '_ |__\___
                              [(o)|___(o)] XB
                              ._________
                              | I__I I_I|_\__I
                              CarPCNetwork
