How to get off grill
  • How to get off grill
    How do I take the grill off? I mean I know there are tabs and such, but the front of my truck is a big chunk of plastic. Is there an easy or secret way of getting these off?
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Ok my horn crapped out when I needed it on the highway today. I was left with nothing but a select finger to express my frustration. I need a new horn and I need it now. My horn is mounted under the grill. There is tons of room there for a new horn (or 4). I can't get the thing off. It seems to be a single piece of plastic (red in pic).
    Any tips before I used a 2x4?
    ,./(0)3
      Go to get your self a Hayne's Repair Manual for your Canyon. You can get them for a automotive shop around your area. It tells you how to take apart everything in you car, so I might be useful during your install as well. Plus there not expensive.
      Installed
      Asus A7N8X-VM - AMD Mobile Athlon 2400
      512 Ram - 60GB HD - Opus 150w
      Lilliput 7" - Rikaline 6010
      [00000000000001100010-] 98% Completed
      Check Out My Install!!!
        Talk about GM quality
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          Any sources online ?
          ,./(0)3
            You might check your local library... I know the local Mid-Continent Public Library in my area usuually stocks shop manuals for every vehicle. If your trying to avoid the resonable cost of your own manual, this might be a good alternative.
            Beyond that, I would just let warranty take care of that problem... I mean, how old can the truck be? Its still under warranty, right? If a horn quits on that new of a car, either it was a POS and THEY should replace it at no charge, your your a road-ragin' fool and use your horn to much. Just my 2.
            Good luck...
            Coach... aka Randy! (I often forget who I really am!) ;)
            ***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
              Did you try going to a service...?
              Renault Megane...the OEM look
                It's definatly under warenty... the trucks only a few months old. The horn was fine but not so loud when the truck was new. Now it's just working intermitently.
                I figured I'd just replace it myself with a louder, better aftermarket horn. Except I can't get the damn grill off!
                ,./(0)3
                  But the warranty should cover it. Try going to your service, tell them it's broken, and when it gets changed, you give the horn you want to the mechanic to replace it.
                    hmmm, i guess i will, since i'm due for an oil change... I just hit 10,000 miles ::tear::
                    ,./(0)3
                      In a few months?
                        3000+ mile road trip
                        ,./(0)3
                          You tried to cross the Atlantic with it?
                            3000+ thats about how far it was for me to drive from GA- CA that really sucked
                              In what time?
