Will this mask work for fiberglass?
  • Will this mask work for fiberglass?
    I was suprised at the limited selection of masks I was able to find online...most were $25-$40, which makes me curious as to why this one is only $7
    Half-mask Respirator
    The filters at the bottom of the page also seem to be much much cheaper than elsewhere.
    So..will this work, or is there a catch that would explain why it's so cheap?
    http://www.smithvicter.com/final.swf
    I think so
    I'm pretty sure that the mask will work but when it comes to fiberglass resin, you will need the Organic Vapor Filter. And I dont' know because I havent called, but It looks like you have to order the filters in bulk.
    Organic Vapor Filter $2.45 x 100 = $245.00
    Aut cum scuto, aut in scuto
      I've been working around fiberglass here and there for 20 years, and I can appreciate the need for a respirator, but if you have some ventilation (working outside) a little glasswork on a dash panel will be virtually harmless. Do you wear a respirator everytime you spray paint? Spraying paint is way worse even if its just from a spray can.
      Fabricator
        I picked up a respirator from pepboys for $20. seems to be doing a pretty good job keep the fumes and dust out.
        AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
        MediaEngine front end, map monkey, netstumbler.
        gps mouse is on the fritz.....stupid technology
          I never wear a respirator when using glass bondo. But when I use resin I do, even if its just a little. I nearly passed out one time a couple years back. You can buy the correct filters in 10 packs at Home Depot. Dust filters, they do nothing (said in best McBain voice)!
          Car: 2000 Audi A4 Avant 1.8t
          Carputer 2.0: removed. Back to stock.
            cool. thanks y'all. I appreciate the info.
              Just work in a really well ventilated area and you should be OK with a dust filter... I bought a cheapy one at homedepot but it said it was ok for fiberglassing...
              '02 GTI
              [Routis '04] [Opus 90W] [160GB Maxtor HD]
              [Lilliput 7" TS] [VIA M10000] [XMPCR]
              [512MB RAM] [Custom housing]
              [Deluo GPS Mouse] [E-MU 0404 Soundcard]
              Progress Meter: [==============|] 99.9%
                No need to go all out like that. Dust mask will be fine.
                I know... Or i'll find out otherwise in my old age. Lets just say I fiberglassed and bondoed in the garage with no ventillation. But sanded outside without a mask.
                Mark
                Website: http://www.greenpowerenthusiast.com/
                Car'Puter Project
                - Xenarc 700TSV
                - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
                - 1x 256MB Corsair XMMS DDR400
                - M2-ATX
                - Belkin 802.11G W-Nic
                - Garmin 15H GPS
                - WinXP SP2 (NLited)
