What is the best finish for custom dash?
  • What is the best finish for custom dash?
    I am at the stage to finish my custom molded screen and was wondering what everyone else has had the best luck with. I have a very fine textured spray paint (looks like about 150 grit sandpaper when applied) but from testing it looks like it will be too glossy.
    I'll get back to you in a couple hours. I'm trying plasticote flat black bumper and trim spray paint.
    AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
    MediaEngine front end, map monkey, netstumbler.
    gps mouse is on the fritz.....stupid technology
      In order of preference:
      1. The tanned skin of my enemies
      2. Vinyl from fabric store
      Chrysler 300 - Fabricating
      http://hallert.net/
        flat black plasti-kote bumper and trim looks very OEM. at least for my honda, it's almost spot on in shine and texture.
          Polished, carved hardwood. Engine-turned billet aluminum or stainless steel. Plastics? Bah.
            It's been almost four years, I stumbled across this while researching which paint to use for my fabbed dash piece.
            Has anyone done anything with undercoating? I'm thinking it would be nice if I could have the sort of rubber-ish coat that the OEM piece had. Unless that's what the Plasti-Kote bumper/trim stuff above gives....
            http://hallert.net/
              just finished my dash using rubberized undercoating.
              The trick is to use multiple coats but thin coats or you will get runs. Also patience in between coats. Being in the last phase of my install I was a little over anxious and as a result I got a run down the flat side of the front finish. But it works great if you have a dash you used a lot of bondo on and have a few uneven surfaces. As I did, it was my first attempt at fiberglass and bondo so there were a lot of imperfections that the undercoating covered up for me.
              New Age Garmin - Skin for RR
                Thanks! I'll try that next if the next experiment doesn't work. I picked up some spray on tool protector.
                http://hallert.net/
                  Sem Texture/Satin Black Paint
                  Brian @Nexations Creations
                  Specialist in Custom Interior Fiberglass OEM Replication Work.
                  AIM: Exus28
                  E-Mail: Exus28@aol.com
                    How about exterior color paint? hnoes:
                    You could get some spray can touch up paint, some nice clearcoat, and make the custom dash really stand out...
                    EDIT:
                    Whoops, i just realized I replied to a year old thread... O_o
                    *grabs flamesuit*
                      EDIT:
                      *grabs flamesuit*
                      1X Ainol Novo Flame Tab
                      4X MK808b
                      3x Perixx Touchpads
                      3x 7 inch Screens
                      1X 7 inch motorized Screen
                      1x Win 7 PC
