HOw to make it look flush?
  • HOw to make it look flush?
    Yes i did jack the picture from a member here. i can't find my camera. Anyways i am trying to make this look flush? i want to know how to do it? i used body filler and it just cracked on me. what else can i try now? my dash looks like first pic and i want to make is like second one.
    Lots of filler, support (eg balsa wood), glass reinforced filler, sanding and patience!
    Make sure you prep the area yout are sticking the filler to by degreasing it and roughing it up with paper to give the bondo a 'key' and use penty of support structure to stop it bending.
      Well i have this. Is this the product i should use? look at that pic
        we have a product called isopon over here, it comes in 2 forms like your bondo. the brittle but easily worked plain stuff and the glass reinforced stuff what is more like araldite. the former (like what you have got) is very prone to cracking when used in thick sections and when the substrate (what it is bonded to) flexes. Fillers like bondo are only designed to be used as thin layers to pad out dents etc so i guess when you are trying to fill a gap between the screen and the dash it is having to take load due to flexing and it only has a small contact area with the dash so it really is not suitable. Try and get something more like an epoxy with fibres in and don't rely on it being able to take load/flexing etc.
        Bondo is not a structual material. It won't take any load and you may as well use cake icing!
          Thanx man. So just use epoxy with fibers in it right? any idea of a product that is epoxy with fibers in america? what is it called.
            Like Scouse Monkey said use epoxy or get the reinforced bondo. It is much stronger then just regular bondo. Use the reinforced stuff to fill in the big hole and then sand it down. Then use the bondo you have to fill in the holes to get it smooth.
            This is the one i'm talking about.
            Installed
            Asus A7N8X-VM - AMD Mobile Athlon 2400
            512 Ram - 60GB HD - Opus 150w
            Lilliput 7" - Rikaline 6010
            [00000000000001100010-] 98% Completed
            Check Out My Install!!!
              You have to have a very strong mechanical bond before using the filler. Filler is not an adhesive. PowerPoxy's Poxy Weld is Kevlar reinforced. Use that to glue the parts together first, but you still need to insure that the areas to be bonded are clean an well scuffed with 80-180 grit scratches.
              3M Automix Plastic Repair is an even better filler to use, but its pricey. That Bondo brand stuff is crap. Go to an Auto Body Supply store and get a glazing filler like Evercoat Metal-Glaze its much easier to use on small projects.
              You can also make a decent sandable filler out of the Poxy Weld by mixing it with Microballoons but you have to work fast.
              Fabricator
                altimat. So just use this "3M Automix Plastic Repair" or i have to use the bondo with reinforced fiber first? and where can i get 3M Automix Plastic Repair?
                  Body shop supply places will have the Automix too but its expensive. The Poxy Weld and Evercoat combo is less expensive. You can try calling for a PowerPoxy distributor the number is at www.powerpoxy.com. Not much else is there on the website though!
                  You can use the reinforced bondos as an adhesive, but they just don't stick as well as epoxy does. Just remember that polyester filler don't stick well to epoxy either. So I keep the epoxy on the back and the polyester resin based filler filler on the front. If it does go over some epoxy its just a thin seam line.
                  I gave up on that Dominion Sure-Seal stuff. I did get one worthless reply, but the replies take 2 weeks to arrive. If it magically appears on my doorstep I'll try it out.
                  Fabricator
                    I used regular bondo and they are starting to crack on the edge, not a good idea.
                      I am wondering if home depot would have Poxy Weld and Evercoat Metal-Glaze filler?
                      And just use poxy weld sand it down and then use the metal-glaze filler right? and is it just one coat of each?
                        I have one extra Poxy Weld you can have it for $18 shipped USPS Priority if you can't find it. Call PowerPoxy first for a local distributor first though. I just picked the stuff up and it was the last two on the shelf at the second Menards I went to so I snatched both lol. The stuff is like gold to me until I find something better and the price is great.
                        The Evercoat is only available from body shop supply distributors its a professional product.
                        You want to thoroughly prep the parts being sure to sand everywhere you will be applying the epoxy from the back. Tape the front seams. Put a nice heavy layer on the back, then use a hair dryer to warm it up. It'll flow some so keep it level until it sets.
                        Then pull the tape and prep the front the same way. Taper away a little material into the seams, and sand the epoxy back to just a thin line in each seam, then fill the front with Evercoat and sand with a block till smooth. Finish with 180. When you think its good "squeegee" on one more very thin coat to get pinholes before priming.
                        Fabricator
                          This the product are you talking about?
                            Yes thats it. Comes in a clear blister pack.
                            Fabricator
                              now the micro ballons. Do i have to use that if i use Evercoat?
