Available Double Din Frame?
  • Available Double Din Frame?
    I've ed the forum and even d but i couldnt come up with anyone who sells a double din frame. I have a Scion Tc with a double din head unit, and I was wondering if anyone knows where I can get the double din frame, so that I can incorporate the computer hardware as well as the LCD screen all within the double din.
    from toyota parts department, or an aftermarket one from Soche.
      tear apart your stock headunit =)
      Stealth OEM spyder
      1204 dot net!
        fleeeeebay, junkyark, local audio shop, your friends are best place. Look for any Toyota double DIN HU. Take out the internal an put the PC in there.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          http://www.crutchfield.com/S-bg4pILA...0&I=003TOYK969
          PC Components:
          My work log
            Dashkit is not the one. He need one that is like the Double DIN radio so he can take out the internal and put the PC (mini-ATX size) in there with the LCD in the front.
              yea thats what i need, like the case of the the double din hu. so that i can stick the computer parts inside. not the dash kit.
                Your other option is fab the case yourself by using the measurement of the double DIN you have. Go to Homedepot/hardware stores and get some galvanized steel and work from there. But it is much easier to go to junkyard.
                  i got mine from the mr2 spyder forums for $20 shipped. If you post there, you might be able to find someone selling for cheap. You could try the other toyota models too... (celica guys tend to ask for more)
                  Stealth OEM spyder
                  1204 dot net!
                    look at ebay for "double din lcd frame for Lilliput 629 & 701" or google it for by by te infotainment solutions. They have it!
