Bending aluminum into a case.
  • Bending aluminum into a case.
    In my previous post in another thread, I mentioned that I was going to mount my Mini-ITX motherboard in a Subaru Gauge Housing, which goes on top of the dash in my WRX.
    Here's the post I made, for reference:
    http://www.mp3car.com/vbulletin/show...9&postcount=24
    I figured that I'll need to form a small box, and I'm going to do it by bending sheet aluminum.
    I ordered a few sheets of Aluminum 5052-H32, 0.09" thick (~2.3mm), from www.onlinemetals.com, a nifty metal and plastic supply store online that does custom cut orders with no minimums, for cheap.
    I had them cut a few pieces to size, and the whole order only cost me $11 for the materials, and another $11 for shipping, making it $22. Not bad at all.
    I'm going to bend the metal into shape using this:
    18" Bending Brake
    I probably should have bought this to make the bending and cutting easier, but it's a little more than I wanted to spend:
    Miniature Shear / Brake
    The formed aluminum case will be about 180mm square, and 60mm tall, and will have a plate in the back for the ports and a slot for a horizontal PCI slot, connected to a riser card.
    My materials and tools should be here for next weekend, so I'll start the work then.
    The resulting box should look like something like this:
    If you want to start bending metal seriously, look for something like these. Be aware Fly Presses are very heavy and really need to be local as shipping will cost plenty.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
      Very nice... kind of like these dies, but in a larger scale:
      http://www.ares-server.com/Ares/Ares...oduct&ID=82816
      I can get 30" bending brakes on eBay for about $40, so now all I have to do is find a bench shear..
        Awesome ... can't wait to see how this turns out! I'd love to make something custom that perfectly fits my setup instead of using the overly cramped C134.
        2004 4runner
          It should be pretty good..
          Some of the other hand tools I ordered were:
          • Nibbling Cutter - nibbles away at metal 1/32" at a time, 1/4" wide.
          • 6-32 Tap, for threading holes for normal PC case screws.
          • M3x0.5mm Tap, for threading holes for the fine-thread screws used in floppy drives, cd-rom's, etc.
          • Machinist's Center Punch - spring-loaded punch, for punching dimples in the metal for easy drilling.
          • Mini Hack Saw - general cutting use.
          The idea is to bend the main frame to fit the gauge housing, adjusted for height, and to screw the square plate to the top, and the rectangular panel to the back.
          It will probably also include holes for ventilation, mounting for a laptop hard drive and slim CD/DVD, and possibly a slim 80mm exhaust fan to vent the air out the top of the pod housing.
            Interesting, looks like you put a lot of thought into the process. Did you think about how are you going to drill holes for ventilation? I had a case that was too bad, it kept the temp high, I wanted to drill holes for ventilation, they did not look good at all, they did the job, but looked real bad. I hope you worked out the details. I had to use hand drill, table drill would have done a lot better job but the case was too big for a table drill.
            By the way, very nice drawing, what did you use, please don't tell me Visio, I would be embarrassed.
              Well, if it was just individual holes, I was going to lay out some kind of grid or pattern on the metal, and use the machinist's punch to indent marks for where the holes would go.. and then just use a hand drill, with the metal backed against some plywood.
              For something like slots, it would be laying out the pattern of the slots on the metal, drill a 1/4" hole at each end, and use the nibbler to cut my way through.
              For a hole for a fan, scribe a circle of the right size, drill 1/4" holes at the 4 quarters of the circle, and nibble away.
              Finish up with a light filing or sanding for the edges...
              And for the graphic, it's just a free CAD/CAM program from www.eMachineShop.com - it's intended for making parts for eMachineshop to cut for you for a price, but it's got a basic 3D view of the parts that I find useful for visualization.
              Of course, if I had a real CAD/CAM program, I could do much more.. but I don't have the thousands of dollars necessary for something like Pro/Engineer or the like.
                Great ideas you got here. Thanks
                  Anybody ever thought of using the alloy case as a heatsink with a l shaped bracket of alloy on top of the chip heatsink then the whole case will remove heat say with an alloy ribbed extrusion on the top?
                  also here is a link to an earlier thread about punching a clean hole
                  http://www.mp3car.com/vbulletin/showthread.php?t=39860
                    Car stereo heatsinks might be useful to bolt onto the back of the case if you are doing this.
                      Both great ideas..
                      I'm not sure I can work an external heatsink into the design, as it would only dissipate the heat into the air in the surrounding area.. I'd still have to ventilate it.
                      And as for punching a clean hole, compression-type hole punches really only work well for smaller holes, and larger hole saws can be difficult to use without a powerful hand drill or drill press.. neither of which I have.
                      I once used a 4" hole saw with a cordless drill I have, and it took forever to drill through, including a few recharges.
                      A better option might be to have a milled heat block on the CPU, attached to heat pipes, and the heat pipes run to the big external heatsink...
                      I could do that if I had a milling machine.. and I could make/get heat pipes and bend them into shape..
                      Actually, I think making heat pipes is possible, but I'd have to research it..
                        [QUOTE=Giuliano]Both great ideas..
                        [QUOTE]
                        How big a hole do you want to cut these go to 50mm.
                        The hole cutter you tried was proberly a cheaper one meant for wood they go blunt quick. If you try an electrial supply place (for trade users) or perhaps a plumbers merchant they sell hole saws to cut metal with and alluminium is real easy to cut. Watch when it breaks through or you end up with a twisted piece of metal spinning on the end of a hole saw
                        http://www.rapidelectronics.co.uk/rk...4566&XPAGENO=1
                          The holes I would need to cut for a fan would be either 60mm or 80mm, because that's what the major PC-sized fans are sized at.
                          But the problem isn't the hole saw itself, it's the power tools I have, being cordless, don't have enough power to drive the larger hole saws easily.
                            Just an idea
                            Looking at your pics, if your mounting your pc in the top of your dash with your moulding knowledge make a duct to blow air from your aircon into the case, and in the winter allow air from outside to circulate around the case (with a membrane around to prevent the ingress of damp)
                              Just an idea
                              Well, I didn't want to cut into the A/C ducts, because to replace the ducts means taking out the entire dash..
                              But yes, I was planning on mounting a slim fan on top of the frame, and venting the air out the top of the plastic cover on the dash.
                              And for winter, I could probably make the fan so I can reverse the polarity to blow warm air in from the defroster blowing warm air on the windshield.
                              A reversing switch would be easy to make with a Double-Pole Double-Throw (DPDT) switch, with a wiring diagram as shown.
                              The Red (+) and the Black (-) lines are the power to the switch. The Green and Blue lines are the wires going to the fan.
                              With the switch covering the left pair of poles, the fan gets normal power. With the switch covering the right pair of poles, the fan gets a reversed polarity power, and should run backwards.
                              And if you get a triple-throw double-pole, you can leave the switch in the middle to turn the fan off completely.
                              However, I would imagine that I would have the fan connected to the motherboard, and the system would control the fan speed based on temperature.
