Alternate fabrication materials
  • Alternate fabrication materials
    I started looking arround for materials I could easily work and not spend alot of money on.
    My first thought was wood, but decided it was not what I wanted.
    Browsing at the local hobby store I spotted foam core.... Thought I would test it out.
    I also found a site showing how some shapes and suggestions on cutting/glueing.
    http://www.deziner.com/site/deziner/...t/foamcore.htm
    It is not my site but it helped me.
    The foam core was $5.00 I already had the exacto/excel hobby knife and the straight edge.
    I'll post pics when I get access to a camera.
    Looks like I made it to 1000 posts. I hope this is still rewarding at 2000 and more.
    TruckinMP3
    Read the FAQ!
    you just reminded me of the foam we use at uni to make blades and airfoils. it is a a dense foam that can be cut and filed and would be perfect for making my dash - right off to pinch some tomorrow.
      I am very pleased, I have the box down to 10 x 10 x 4 inches. It is much smaller than the old metal briefcase I was using.
      Hope it helps others.
      Cheers
      TruckinMP3
      Read the FAQ!
        if you want something a little more rigid yet pretty easy to work with try pvc. I made a monitor frame with the stuff and it looks really good.
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
          any pictures?
          How about some pics of it, pls.
          thanks
          04 Corolla
          Modifications:
          Upgrading pc 99%
          Progress
            hrmmm - interesting...wonder how this stuff would hold up to the chemicals one would use in fabrication materials.....
            Jan Bennett
              I have worked with foamcore in the past. Once you start working and become accustomed to it, you will see that it is easy to get the results you desire.
              On another note, i have seen this stuff catch on fire pretty easy. In building a case are you planning on doing anything in particular to reduce the chance of a fire?
              -S
                thanks
                I'll post pics but not until the whole car pc (monitor, pc, amp, and speakers) are completely installed, look out for a full write up too
                M10k
                My Car Pc Install
                My Boat Pc worklog
                  -S
                  What would the PC due to cause the foamcore to light up? I can think of no reason to be concerned with this.
                  TruckinMP3
                  Read the FAQ!
                    there is a 12v wire going to the pcu. if there was a short and it wasn't fused correctly it could lead to problems.
                    aslo; foamcore will provide very little structural rigidity, i wouldn't use this in an exposed application.
                    M10k
                    My Car Pc Install
                    My Boat Pc worklog
                      I admit that the chance of this occuring is very slim to null.
                      I just wanted to bring up a possible issue that could be a concern to someone.
                      no harm done
                      -S
                        Actually it comes in several thicknesses... and short spans are fairly rigid.
                        Still it is not sheet metal.... I belive that was the point of the thread.
                        TruckinMP3
                        Read the FAQ!
                          cool; that's news to me. i didnt realize that it came in anything but the size that you got for mounting posters.
                          M10k
                          My Car Pc Install
                          My Boat Pc worklog
                            You can also change the structure by ribbing. much like adding dimension to sheet metal to make it hold a shape.
                            TruckinMP3
                            Read the FAQ!
