1/8th Inch plywood?
  • 1/8th Inch plywood?
    Dose lowes sell any 1/8'th inch plywood? or some thing similar? I need some thing to make a new rear deck peice for my car. Also if any one knows a good place to get nagahide let me know.
    1/8" plywood would be next to impossible to make...lol
    why not look into some 1/4 hardboard? (masonite) anything much more thin and you won't have anything to bite into with screws when you want to secure it down or secure speakers or anything to for that matter....
    Jan Bennett
      Ditto on what Red said + then cover it with spray adhesive and some sort of cover amterial (vinyl, nawgahide etc..)
      Try Walmart for fabrics etc.. or any big craft type store.
        walmart or a fabrics store - like Hancock....if you have one.....a fabric store will have a ****E load larger selection
        Jan Bennett
          for the orig plywood idea - dont they use real thin stuff like that in model boats etc?
          Wont b cheap tho...
          92 Subaru Legacy Wagon
          Epia MII12000 :D
          Morex 80W
          120G External HDD
          16x2 Charater Display
          Creative IR Remote
          VIA Sereniti 2000 Mini ITX Case
          7.2Ah SLA Tank
          PCMCIA 802.11b
          256DDR Ram
          Diamonds are for girls- wise men follow the stars
            Wont b cheap tho...
            Yea, I used to build models as a kid and recall using some of the thin plywood material for things like firewalls on airplanes. I'd check a hobby shop, but it may be difficult locating a large piece if that is what you need.
            "Protecting Privacy and Free Speech Online"
            http://www.eff.org/
              Balsa wood? that's too think... how think is luan plywood? it's cheep and probabaly 1/8 inch
              ,./(0)3
              '04 Canyon 4x4 pickup
              [---PC on hold----working on external fiberglass "tool" box---]
                rear deck peice?? is tht th parcel shelf? i remade one for my mzda with some 10mm ply. 1/8 is pretty thin...
                you could try to get some thin wood like cedar or whatnot for tht.....
                Epia MII12000 :D
                Morex 80W
                120G External HDD
                Creative IR Remote
                7.2Ah SLA Tank
                PCMCIA 802.11b
                256DDR Ram
                  i purchased a 2x4 sheet at home depot, or you can try www.balsausa.com
                  New System in progress:
                  M10k
                  Phaze TD1500 ~> Seas g18rnx/p
                  Zapco Ref 500.1 ~ 12" tc-9
                  Transflective Xenarc
                  My Car Pc Install
                  My Boat Pc worklog
                    if you want summit 1/8th thick use hardboard - cheap as chips. But for making a rear deck you probably want summit thicker like the 1/4 inch red sugegsted. If you use MDF don't forget you need a proper mask when cutting it.
                      proper mask? what? i've been cutting this stuff for the last week... why do you need a mask? and what is the proper kind?
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        you can get plywood as thin as 1/32.
                        luan play aka door pannel is about 1/8 it's probably what i would use for this application.
                        If you want something a little stronger and easier to work with look for occum plywood at a marine lumberyard. It is availible down to 3mm thickness (I would likley use 4mm) and in these thicknesses it goes for about $35 for a 4x8 sheet.
                        depending on how large of an area you need to span i may concider putting in a framing member to help prevent it from sagging. Just one running front to back in the middle would likley do the trick.
                        good luck
                          sorry i was wrong you can get it in 1/64 too
                          http://www.aircraftspruce.com/catalo...nnishbirch.php
                            MDF dust causes cancer. Ypu need a proper respirator type mask (your DIY place should be able to advise you). The simple paper masks are no good.
                            We used to cut MDF at school before they realised it caused cancer - oops!
                              MDF dust is nasty stuff.. possibly carcinogenic.
                              Steve
                              ....Yes, I know it has a stupid name, those crazy Japanese!
