Screen position opinion wanted
  • Screen position opinion wanted
    I have a silverado/ I am mounting an 8" lilli in place of the stock stereo and a/c controls. My question is, should I angle the screen about 10 degrees so that the screen in perpendicular to my line of sight, or keep it straight up and down like the stock stereo. It is a little easier to see when it is rotated, but will it look bad?
    Another question, my dash angles towards the driver. Should I recess the screen more on the passanger side to make it so the angle is equal between the driver and passanger? I hope this is clear. Here is a pic of the screen resting in the dash. The pic was taken from the center seat. You can see how it is slightly angeled towards the driver. It wouldnt take much to make it centered. Maybe recessed an extra inch on the passenger side.
    edit: I dont want people to be confused. I know the screen is higher on the right than the left in the pic. That is because of the wires. I need to make a small cutout for them. This will be fixed. That's not what I mean by rotating it to the driver. Obviously that looks like ****. I am only talking about rotation about the x axis and y axis. Rotation about the z axis would be retarded.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    definitly keep it straight!
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
      More specific please. Straight as in straight up and down, or straight as in with the dash, or straight as in straight across so that passanger and driver have an equal angle?
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        Please keep it straight up and down like the stock radio. PLEASE.
        -iBase MB870 mini-ITX/P4 1.8GHz/256MB/ATI Radeon 9100 IGB onboard video
        -Alpine MRV-F450 5 Channel Amplifier
        -Lilliput 7" VGA touchscreen
          IMHO:
          Driver == king (queen) the display should be optimaly faced for their best viewing. The passenger(s) can lean and view w/o jepardizing life/limb. --- or get their own displays.
          •Micke
            Why is that? I've noticed a lot of factory nav systems have the screen tilted back. It cuts down on glare and makes the screen appear brighter becuase you are looking perpendicular to it. Those are just some reasons why I might want to tilt it back.
            2.4 celeron
            150 watt OPUS
            micro atx
            xp pro
            tv/radio tuner card
            audigy
            Dual monitor Radeon
            802.11G Mimo
            xm pcr
            dvd
            gps
            IGuidance
            dual optimas
            battery isolator
            15" screen
            My Truck
              Originally posted by grepzen
              IMHO:
              But most vehicles don't have the angled dash and it doesnt seem to be a problem for them. Does this mean you think i should tilt it back about 10 degrees and leave it horizontally parralel to the dash as it is now? Don't mind me playing devils advocate, I just want to make the best choice.
              2.4 celeron
              150 watt OPUS
              micro atx
              xp pro
              tv/radio tuner card
              audigy
              Dual monitor Radeon
              802.11G Mimo
              xm pcr
              dvd
              gps
              IGuidance
              dual optimas
              battery isolator
              15" screen
              My Truck
                I had something like this in mind. Sorry altimat. I hope you dont mind that I modified your pic. Recessed more at top to angle toward both driver and passangers eyes. Also I was thinking to straighten it out left to right to have an equal angle to both viewers.
                2.4 celeron
                150 watt OPUS
                micro atx
                xp pro
                tv/radio tuner card
                audigy
                Dual monitor Radeon
                802.11G Mimo
                xm pcr
                dvd
                gps
                IGuidance
                dual optimas
                battery isolator
                15" screen
                My Truck
                  Bump
                  2.4 celeron
                  150 watt OPUS
                  micro atx
                  xp pro
                  tv/radio tuner card
                  audigy
                  Dual monitor Radeon
                  802.11G Mimo
                  xm pcr
                  dvd
                  gps
                  IGuidance
                  dual optimas
                  battery isolator
                  15" screen
                  My Truck
                    devil schmevil...
                    you.. the driver has that big round ring thing that makes the truck go where YOU want.
                    the displays you require/want should also be as YOU want. you can angle it any way that makes it easiest for you to read AND still make it look good. as for other's viewing.. if you're so hung up on giving them an eye of it.. then make it swivel-able so they can view too if you like. this.. is your world
                    •Micke
                      Your right. So I guess my real question is, if I rotate the top back about 10 degrees and rotate it about the y-axis so that driver and passanger have the same view, will it look stupid?
                      2.4 celeron
                      150 watt OPUS
                      micro atx
                      xp pro
                      tv/radio tuner card
                      audigy
                      Dual monitor Radeon
                      802.11G Mimo
                      xm pcr
                      dvd
                      gps
                      IGuidance
                      dual optimas
                      battery isolator
                      15" screen
                      My Truck
                        IMO i think you should keep it rotated so the screen is level, and recess the top in a touch, it would not look bad at all BUT, thats just how i feel, its your truck, your dash your screen, so do as you wish
                        New carputer install starting soon!
                        Project status: 0% still in the planning stages
                        My Crappy site
                          off topic but is that a US Speedo gauge face set you have?
                            IMHO:
                            get their own displays? what would they just bring there own and just plug it in?
                            lol
                            i say keep it straight like in how the radio and stuff was
                            my wish list:
                            http://i4.photobucket.com/albums/y13...tSignature.jpg
