Paint inside of computer case
  • Paint inside of computer case
    I'm making a custom fit case out of FG to fit my glovebox. Once fabricated, I want to paint the inside of the case black.
    Anything I should know about painting the inside of case? Particular paints to use (or stay away from)? I'm thinking about conductivity.... Any latex based spray paint should be fine, right?
    just don't let you're mobo touch the case lol, i have a alu case (made it myself) used rubbers between the mobo and case works fine
    my destinator map resource down permanently
      Never thought of using rubbers for that.
      Interesting.....
        make sure you get the non-lubed ones...=]
        Jan Bennett
          i think they where seal rubbers for piping of some sort just got them at the local hardware shop, they are about a CM in diameter and 4-5 milimeters high so i used 1 and a half to keep the mother bord up and just put screws thru them ..
          here is the best pic i have sorry not a very good one just never thought about photographing the rubbers :P:P damn that sounds ... well wrong :P
            heh - I'm talking about different rubbers....the ones that you were joking about...hehehe
            Jan Bennett
              i know :P just trying to help the ts :P.. dunno why i quoted you though :P
