3/4 inch Plexi Glass/Diamond Plate Amp Box
  • 3/4 inch Plexi Glass/Diamond Plate Amp Box
    Though some ppl might enjoy this unfortunatly i dont have pictures of the building just a somewhat finished product.
    here is a picture of a plexi glass amp box i contructed on the floor of my van
    To do so I needed to raise the floor by roughly 2 inches
    I laid a piece of 1/2 in ply wood and a 2x4 flat side down and built up the entire back of the van
    Then I got a 3/4 inch (originally was gonna be 1/2 in but i couldnt find it) piece of plexi and mounted it in the 15 inch by 36 inch hole i had made for it.
    I laid it in like the rest of the plywood that had been placed on the floor with a slight lip all the way around.
    The I got a 17 inch by 40 inch piece of 1/4 inch diamond plate a jigsaw and a drill and went to town. measured out the dimensions of the chevy emblem and cut (not as easily said than done) If i could have found 1/8 in i would have but i went to a metal shop by me and the guy charged me only 20 bux for a 17 by 40 inch sheet which he cut from a half piece he had.
    I went thru like 4 blades 24 tooth metal blade if i recall right. i could be wrong
    so instead of the amp i just have the piece of carpet i cut out of the hole for right now till it gets warmer then i might even consider putting my car pc there or even doing a oneway mirror (infinity mirror) effect there.
    Here Is where I riase the floor you can see at the top where it white and then becomes ply
    outside2
    A view about to go in the back
    I plan on putting a wraparound couch in the back here
    Ill post some other pix a little later thanks for checking it out
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Looks nice! I like the chevy logo that you cut in the diamond plate .
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
      there was a thing on pimp my ride the other day where they put a couch etc in the back of some ****ty old van - the couch also doubled as a sub box with 2 subs in it...
      92 Subaru Legacy Wagon
      Epia MII12000 :D
      Morex 80W
      120G External HDD
      16x2 Charater Display
      Creative IR Remote
      VIA Sereniti 2000 Mini ITX Case
      7.2Ah SLA Tank
      PCMCIA 802.11b
      256DDR Ram
      Diamonds are for girls- wise men follow the stars
        this looks really nice....what type of molding are you using around the edges of the chevy logo?
          i used black automobile door molding (pepboys) and cut it to fit
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          CarPCNetwork
            how did you cut the diamond plate?
              a jigsaw and a metal blade and some masking tape with the lines drawn on it
              .______
              | '_ |__\___
              [(o)|___(o)] XB
              ._________
              | I__I I_I|_\__I
              CarPCNetwork
