to: mister altimat
  • to: mister altimat
    Hey mister altimat I don't know if you remember me but I was the one that sent you some PM's asking you for the price on a dash for a nissan xterra.
    my idea was to move the radio down to the empty space, this open have a cover that is hold to the dash with some screws,then put the xenarc were the radio was.
    I finally start doing the fabrication part of the project and I been reading the fabrication forum for a while and I know that you Know what you are talking about.
    So I went to the local body shop supply and I bought the evercoat metal glaze, and the epoxy plastic weld fom the auto parts.
    I already cut a couple pices of plastic, like the one that separate the upper hole with the lower hole (I make one single hole that mesure abouth one feet).
    So the xenarc fits perfect were the radio was but the radio I have to make some king of frame to make look nice.
    that part I think I have it figure it out but now I ran in to a problem,besides the dash pice I have to change the shift console a little bit.
    I cut the pice,fix it the way I want it but when trying to glue it together with the epoxy It doesn't.
    So the diference between the dash part and the shift console is that one is
    ABS and the other is PP-T20 so my question know is:
    *The epoxy do'nt work with PP-T20 or was the problem
    *If no what product I need (the guy a the body supply offer me this product that is for "problematic plastic" this cost $25 bucks and he is gonna let me borrow is gun...... so I don't know if this is what I need.
    thanks for any repply from you or any other that can help me with this...
    P.S: I think I been using the cheap epoxy..... I just find this epxy:
    http://store.tackletogo.com/evsearepglu.html
    Compare with the one that is in one of the fabrication threads:
    http://www.iboats.com/mall/index.cgi?prod_id=38083
    let me know what you think....
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    In general the faster-setting epoxies are the weakest. With PP you have to use an adhesion promoter such as 3M Automix 5907 Polyolefin Ahesion Promoter or nothing will stick.
    Fabricator
      ok so I will get this at the same body sho supply..... and I can stilll using the same epoxy (the one from auto parts or should I change to 3M automix platic repair...???....and the evercoat metal gaze work has filler for PP or do I need something else (I'm gonna end penyless after spend all this money)
      thanks in advance for your repply
      Nissan Aux-in MOD
        Your best bet will be the 3M Automix products though they are most expensive.
        Fabricator
          metal glaze works as a filler on PP after I glue it together???
          I think I'm gonna get the 3M automix plastic repair after spend $1200 in hardware I think I can get $50 dollars more from "the bank" (my girlfriend-kind of wife-being together for 8 years-she controls the money)
          what are the steps to work in PP....?? sand it 80-180 clean it.........
          thanks....
          Nissan Aux-in MOD
            All 3M products include excellent preparation instructions, but yes clean, sand, fill.
            Fabricator
              Nissan Aux-in MOD
                The local bodyshop ofers me SEM Polyolefin Ahesion Promoter so is ether this or buy the 3M automix online........
                Any sugestion for this SEM product???
                Find the 3M automix platic repair for $20.76 and the adheresion promother also 3M automix for $19.83 at sherley willians
                Nissan Aux-in MOD
                  SEM is fine. Not sure about using the Metal-Glaze with it though. I'd try a little test area first. Make sure it sticks well. The Automix is probably your best bet though. I stick with epoxies on PP.
                  Fabricator
                    no..... my qustion is, if after I glue it and is rigid I can use the metal glaze to fill the cracks,gaps etc??
                    Nissan Aux-in MOD
                      no..... my qustion is, if after I glue it and is rigid I can use the metal glaze to fill the cracks,gaps etc(just like when fixing the ABS dash panel)?? or I need another kind of filler????
                      So this will be the steps:???
                      *Sand it and clean it.....
                      *Use the 3M adheresion promoter(whetever directions it have on the lable), apply the 3M platic repair on the back and put tape on front.....
                      *Use the metal glaze filler to fix the gaps on the front....
                      So is this right????
                      thanks Altimat for share your knowledge......
                      Nissan Aux-in MOD
                        Yes that should work. Just make sure it is rigid after gluing because polyester filler is not very flexible. It also doesn't stick to epoxy.
                        Fabricator
                          Thanks for all your help..... I really learned a lot of fabrication with your tips
                          Nissan Aux-in MOD
