2002 Porsche Boxster S w/Tview
  • 2002 Porsche Boxster S w/Tview
    My first attempt so be nice.
    System Consists of Tview 7" Touchscreen with a Toshiba Portege Laptop running a stripped version Windows XP (A Powerful PII 300 w/ 160MB of Ram!!)
    The Front End is Road Runner
    The GPS Software I am using is Garmin's NRoute.
    The Screen is held in place with a lot of Bondo. I sanded that down and put Flat Black textured paint on it.
    I LIKEY I LIKEY soon as it gets warm i will start my bondo creation : / im scared
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
      Is this Dale Zelinsky from PPBB?
        not going to fill those gaps?
        where is the bondo? behind the screen?
        that set-up could look so extremely slick if it were filled in!
        Jan Bennett
          Are you refering to the gaps along the top?
          If yes, how do you suggest filling in such a tight area?
            all of it - the top and the bottom and the sides - just flush it in and fill all the gaps - it's what bondo is used for most of the time....
            Jan Bennett
              The bottom can't be filled because that is two seperate pieces of the car. The OEM nav system has that gap.
              Not sure what I could do with the sides.
              Here is a pic of the OEM system:
                Looks nice!
                What would look even nicer is is you'd buy a faceplate like the one from the original nav and cut/bondo your screen in. Make it more flush even.
                But it already looks nice (maybe just clean it a bit and take another pic )
                List of front-ends/usefull apps
                XTroniC | XTroniC Direct
                  You're a brave guy.... Not sure I would want to have a go at a Porshe Boxter.
                  It takes a lot longer than any of us ever imagine to get the finish that we are all looking for.
                  Bit more time with the filler and sander and you will have a really nice install.
                  Prem
                  Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
                  Modified Sproggy PSU
                  Custom made automatic start-up/ shut-down controller
                  Dual 2.5" HDDs
                  Laptop DVD Reader
                  D-Link FM Radio
                  5" PSOne LCD
                  Installed and working. 75% complete.
                    I like that H/K reciever
                    Does it have many features? (like 3 sets of RCA outs, and an aux in)
                    Matt
                      Originally posted by stoodo
                      The piece is part of the unit. Oh well. I will try and clean it up a little more. Like I said first attempt
                      part of a unit?
                      not sure I follow here?
                      the screen is part of a unit? the side pannels are part of a unit?
                      hu?
                      Jan Bennett
                        Matt
                        It is an HK traffic pro. I believe it has 3 sets of RCA outs, but I don't really know because it is plug and play as a replacement for the factory radio. I never used the plugs it came with. It does have the Aux in though.
                          another possibility (for the side gaps at least....)
                          when you dismantle the dash, which bit comes off first? the buttons along side, or the lcd bit?
                          coz you could build up the front piece to follow the contour of the side, but not be actually connected....
                          92 Subaru Legacy Wagon
                          Epia MII12000 :D
                          Morex 80W
                          120G External HDD
                          16x2 Charater Display
                          Creative IR Remote
                          VIA Sereniti 2000 Mini ITX Case
                          7.2Ah SLA Tank
                          PCMCIA 802.11b
                          256DDR Ram
                          Diamonds are for girls- wise men follow the stars
