Considering a screen in my '92 Vette.
  • Considering a screen in my '92 Vette.
    First post here. I am considering putting a carputer/screen in my '92 vette. It would be mainly used for 2 things- GPS Nav, and Data logging/chip burning while I am at the track. As far as hardware/wiring goes, I think I am set, however, I am having some trouble with where to actually put the screen. Now, the widest I can seem to get space in the dash, is 7". It looks like the 7" touch screens have a width of ~ 7.5". I have attached an image of the dash area in question. The radio is non-standard size, and is about 6.5" wide (for reference). The A/C controls, and the status panel above them, stick out about another 1/2 inch past the radio (cant really be seen in the pic).
    I'm wondering if anyone can figure out a good way to install a 7" screen in this space. Re-locating the A/C looks like it would be a BEAR (there is a mechanical arm that hooks up to the back of the A/C controller, and it doesnt look like it could be relocated). However, I have no qualms about eliminating the radio (I can just use a radio card in my car pc). Any tips?
    I would probably see if LCD will fit in radio slot, if not, would probably put CarPC into Radio slot, and have screen sticking out in front.
    If you already have a spot for the hardware itself, maybe even leave Radio where it is, and just build arms or somehow place LCD over radio.
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    2000 Mitsubishi Eclipse GT
    - V6 216hp
    - KYB-AGX adjustable struts
    - Konei Alloy 17" rims + Pirelli P-Zero's
    - AEM slotted brakes
    - AEM CAI
      the actual screen in most 7" touchscreens (lilliput xenarc) is only about 6" wide, of course you need a little more space than that for the surrounding bit but i have no idea where you pulled the 7.5" number from
      Signature: [==||========] 20% complete
        That value was pulled from the mp3car.com store:
        ex- the Xenarc 700TS
        Dimension (in): 7.75W x 4.75H x 1.38D
        Does anyone have the exact dimensions needed if you pull the guts out of the case?
          hey... you look familiar!
          http://www.mp3car.com/vbulletin/show...5&page=3&pp=15
          page 3
          New System in progress:
          M10k
          Phaze TD1500 ~> Seas g18rnx/p
          Zapco Ref 500.1 ~ 12" tc-9
          Transflective Xenarc
          My Car Pc Install
          My Boat Pc worklog
            looks like you'll be able to get the screen to fit, even on that screen there is a metal frame that can be covered my the radio bezel
            M10k
            My Car Pc Install
            My Boat Pc worklog
              Originally posted by scott_fx
              I guess what I would need to do is 1) cut out a piece of paper for the screen case dimensions, and see how it would fit, 2) cut out a piece for the minimum size if you take the screen out, and see how that would fit. Anyone have the dimensions for #2?
              Doh.. looks like #2 is answered in that thread! my bad.
